#26 | |
Re: 5.3 with sm465 4 speed?
#27 |
I don't plan on having the PCM reprogrammed when I put the TKO in, the speed signal doesn't matter much when you have a manual trans unless you are running a electronic speedo. Since I'm running the cable drive speedo off the trans the PCM just needs to see a speed signal to left it know it's off idle and adjust. TKO has both cable drive and a Ford 11 pulse VSS so I'll have a signal to send to the PCM.
#28 | |
#29 | |
#30 |
#31 |
Yes those are the transmission related parts you'll need. Stock linkage and fork works. Also if you haven't bought motor mounts yet, I would recommend CarShop CSP2370 plates, they are of the 1" setback design and place the motor in the right spot, you will not have to modify your driveline if you are using the stock SM465.
#32 | |
#33 |
And what VSS model are you using as well?
#34 |
I'm actually not using a VSS at this time, but if I was keeping the VSS I'd likely use this setup from Jags That Run.
http://jagsthatrun.com/Pages/Parts_S...ctor-Diff.html There are other solutions as well that would work, I believe some folks use a 8000 pulse inline sender that connects to the speedometer cable. |
#35 | |
#36 |
What manifolds/herders are y'all using with the z bar linkage and sm465? I've got a c20 and about to put a 5.3 in it and want to use the factory linkage.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#37 |
I used a 98 Camaro manifold on the drivers side.
#38 |
And it worked with the z bar?
