12-05-2016, 06:08 PM | #401 | |
Re: What did you do to your Blazer/Jimmy today?
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
12-09-2016, 02:35 AM | #402 |
Finally got the rear wheels. Wasn't sure if I'd ever get my Coys. Customer service is something else.
12-09-2016, 10:11 AM | #403 |
Looks awesome! Those wheels are perfect!
12-10-2016, 12:54 PM | #404 |
Got some metal work done.
12-10-2016, 06:11 PM | #405 |
No more flu stones floor. Lol. Looks good
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
12-22-2016, 01:55 PM | #406 |
Took my best girl to Lowe's yesterday to buy an air compressor. Thought I'd snap some "action" shots while waiting
Got home and started sanding down the top. |
12-22-2016, 04:52 PM | #407 |
Great looking truck. I just unburied mine from a foot of snow and drove it around the countryside for awhile.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
12-22-2016, 06:25 PM | #408 |
Oh nice. Luckily here in California I can still drive around a little in the winter w/out freezing my face off. I like the look of your white body / white top, still debating on whether to paint my top white or black.
12-22-2016, 06:59 PM | #409 |
Pulled the motor to replace gaskets,clean everything up and paint the frame and engine. Got the motor pulled, but didn't get any pictures.
Posted via Mobile Device |
12-22-2016, 07:14 PM | #410 |
Today I machined a billet aluminum cup holder insert for my console.
12-22-2016, 09:50 PM | #411 |
I'll bet that made a lot of chips! I like it, Rg
12-22-2016, 09:57 PM | #412 |
12-22-2016, 10:56 PM | #413 |
Nice, CNC or manual?
12-22-2016, 11:36 PM | #414 |
Mine came with a black double wall top and it looked fine. I found the white single wall top and liked it better. In Colorado, the white top worked better temp wise (I suppose...) The extra UV also fades everything there, so I left it white. Now I'm in Northern Michigan and I'm thinking that once I get all the body work done, I may go back all gun metal gray... Too much white around here. I'm getting cabin fever.
12-22-2016, 11:58 PM | #415 |
Cnc. Haas tm2
01-14-2017, 01:39 AM | #416 |
Pulled this stuff out of my 71 CST. The center consol has 4 speakers and in it and two subs. The two amps were under the front seats. Wiring was a cluster f**k from the firewall to the rear bumper. Fixed the intermittent no start and wouldn't turn off issues. Turns on and off with the key like it should now!!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
01-14-2017, 05:59 AM | #417 |
Interesting center console the p. O. Had in there.
01-14-2017, 10:58 AM | #418 |
Big Block
01-18-2017, 10:48 PM | #419 |
Consol and amps are in the Blazer parts for sale area now.
Horrible wiring job by PO was back feeding voltage from the ACC side of igintion switch causing the engine to run with the key in the off position.
01-18-2017, 10:59 PM | #420 |
Po Wiring is not Fun. I had to Go Through and do the same thing with mine. So Many wires going To nowhere and cuts and Splice to half The dash. None of the gauges worked either. Is still like romeomeday require the truck as you have. It would Be much easier than trying to remember all the shortcuts I hadn't to fix and Still rig some places to get a strait looks bE wire Where it Was Supposed to be.
01-23-2017, 10:47 AM | #421 |
Restored my console this weekend. Before picture
01-23-2017, 10:48 AM | #422 |
And after
01-23-2017, 10:51 AM | #423 |
Also installed a Camaro tach.
01-23-2017, 10:56 AM | #424 |
Good job beau. Looks like that tach belongs there.
01-24-2017, 10:09 AM | #425 | |
2WD Jimmy
