Old 01-01-2017, 09:19 PM   #1
Chevyaz
Blower motor
Can someone please tell me what the hell is a flapping sound coming from the blower motor area on my truck. It makes the sound when I start the truck and when I turn it off. And after I turn off the heater. The sound doesn't last long maybe about 15 seconds or so. My heat works fine and the ac works also. Its a 1994 gmc silverado truck 350 5.7 2wd.
Chevyaz is offline   Reply With Quote
Old 01-01-2017, 09:57 PM   #2
sntrym95
sntrym95's Avatar
Re: Blower motor
The recirc door opens when you turn off the truck so the air pressure from shutting the door doesn't prevent the door from shutting. It will close when you start the truck.
Mike
sntrym95 is offline   Reply With Quote
Old 01-01-2017, 10:01 PM   #3
Chevyaz
Re: Blower motor
Okay, but what is the flapping sound im hearing ? That is my question.
Old 01-01-2017, 10:04 PM   #4
Chevyaz
Re: Blower motor
Or i should ask why is it making a noise.
Old 01-02-2017, 01:09 AM   #5
91short
Re: Blower motor
Only one way to find out, take it apart and have a look. There are no cabin filters in these trucks, so something could be in there that's not supposed to be.
91short is offline   Reply With Quote
Old 01-02-2017, 08:17 PM   #6
diveplane
Re: Blower motor
bad actuator trace the faulty unit.
diveplane is offline   Reply With Quote
Old 01-02-2017, 08:22 PM   #7
Chevyaz
Re: Blower motor
Where is that pesky thing located?
Old 01-02-2017, 09:16 PM   #8
diveplane
Re: Blower motor
youll need to climb under dashboard turn ignition on
to find the noise flapper moving up and down.
i think our chevys theres 3 of them.
Old 01-02-2017, 10:09 PM   #9
sntrym95
sntrym95's Avatar
Re: Blower motor
You can reach under the dash, behind the blower motor and move the flap with your fingers. Try that first, and see if it makes noise. then try to find if something is in there that should not be.
You can replace the recirc door actuator with a little bit of patience and a 1/4 air ratchet if needed. It's tight in there so a regular ratchet won't work.
Mike
Old 01-03-2017, 02:50 AM   #10
68 50th
68 50th's Avatar
Re: Blower motor
http://67-72chevytrucks.com/vboard/s...d.php?t=257463
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 01-03-2017, 08:14 PM   #11
Chevyaz
Re: Blower motor
That thread was just what I was looking for. Chevy Tech does it again. Awesome info.
Old 01-04-2017, 07:35 PM   #12
mountie
mountie's Avatar
Re: Blower motor
I replaced nearly everything in my truck ( '88 GMC 2500 w/ 378,000)
I replaced my blower motor & barrel fan. The darn fan seems to make a slight knocking sound sometimes. I looked / reinstalled 3 times ( even got another fan exchange from auto parts).... Beats me.... it seems to fit .....
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 01-04-2017, 07:41 PM   #13
Chevyaz
Re: Blower motor
Check out Scottys Detailing on YouTube he posted a video last night about the hvac on our body style Chevy trucks . It's got some good info.
Old 01-17-2017, 06:55 PM   #14
diveplane
Re: Blower motor
ok i was wrong only one that controls all 3 vents
i found a video might work for u, just lube the spring and mechanism
under dash might work for u.
https://www.youtube.com/watch?v=YDpLZZaih9c
Old 01-17-2017, 06:59 PM   #15
Chevyaz
Re: Blower motor
Thanks diveplane. Thats perfect. Good work.
