09-30-2016, 09:38 PM | #401 |
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
So, here is the compression readings...
Cylinder hone and ring job? Full rebuild? Any thoughts? |
10-01-2016, 11:42 AM | #402 |
No, Chevy blue was not used on the 283, dark gray was used. The aftermarket does not offer any correct engine paint formulas ( either blue 230-250, dark gray 283 or green 292 327) for any '63-'66 Chevy Truck. Apparently they feel theres not a big enough market for this product, I think they are very wrong. Nobody has seen more low mileage original trucks with documentation than 60-66, the accurate info he offered has come from many years of extensive research, we are lucky to have him in this hobby and on this forum.
10-02-2016, 12:16 AM | #403 |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-02-2016, 01:24 AM | #404 |
10-18-2016, 09:56 PM | #405 |
Anyone have a good source for the original grey for the 65 283 motors? My 65still retains its factory grey paint. I do have the original grey valve covers for my engine. Also, we have a good automotive paint supplier in our area here in central Pa. I'm thinking about pulling the motor this winter, cleaning things up a little and seems like a good time to respray the block. I could take the valve covers in for a paint match. But, perhaps someone has done a spray card. In the vintage Porsche community, we have a few guys that have done the research on correct paint colors. They offer these paint spray out cards for a small fee. Any thoughts?
10-21-2016, 10:15 PM | #406 | |
12-01-2016, 02:12 PM | #407 | |
With all that said I do have a question, I am trying to figure out what color the white colored accent is for the door panels? And is that "white" color only to be in the recess or on the entire center of the panel. I admit I have seen both now. :confused: My '66 is nothing like your guys have but I am attempting more a resto mod since really only the body and rear end were original. I swore I saw the colors on this write up but I've been wrong before. Any help is appreciated. And keep the info (and pictures) coming... |
12-02-2016, 10:01 AM | #408 | |
Rollin' Old Skool
https://flic.kr/p/ysC6r3
12-05-2016, 11:14 AM | #409 |
cool thanks for the response. Is it the white or an off white/ivory? do you happen to know the correct paint code?
12-06-2016, 09:50 AM | #410 |
Rollin' Old Skool
I'm not sure. Hopefully one of our fellow factory-correct members with more knowledge can answer that.
12-06-2016, 11:31 AM | #411 | |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
12-17-2016, 04:11 PM | #412 |
Hey everyone forgive me if my questions have already been answered in previous posts...(the new guy and not too familiar with site yet) I'm looking for matching paint numbers for my '66 C10. Truck is the 503 Light Green. But need correct match for 250 engine, the fawn firewall, and correct Ivory white for two tone body.
12-18-2016, 02:52 AM | #413 |
Was there ever a seal or gasket of any type between the inner wheel well and the inner bedside on a fleetside.
http://67-72chevytrucks.com/vboard/s...d.php?t=620707 |
12-19-2016, 11:31 AM | #414 |
boy .... do i have some homework to do before i start tearing at my truck =/
dont want to hear excuses, i want to hear solution(s) |
01-15-2017, 01:58 AM | #415 |
01-15-2017, 10:57 AM | #416 | |
1964 and 1965 1966
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 11-23-2017 at 10:21 AM. Reason: add |
01-16-2017, 11:36 AM | #417 |
Wow, I never realized that the different years had different door panel paint schemes. Thanks
01-27-2017, 11:10 AM | #418 |
Is this color original that I found on my '64 rearend?
01-27-2017, 10:44 PM | #419 |
It looks like it could be a factory inspection mark. Brushed or sprayed-on in a very inconsistent manner as it passes some check station. You often see them on the front suspension where grease has covered and preserved them.
02-03-2017, 11:53 PM | #420 |
Found some green paint on the edge of the steering pump and bracket.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
03-30-2017, 10:06 AM | #421 |
What color was the 283 in this time period? Thanks
04-03-2017, 11:47 PM | #422 |
What is the timeline on which outside door mirrors heads were used? AFAIK there's the round head offset, round head center mount, and the rectangular (not coast to coast) ones. Did they change at year end, or was it a change over when the old stock ran out?
04-04-2017, 08:46 AM | #423 | |
http://www.ebay.com/itm/122359424255...%3AMEBIDX%3AIT Then for 1960-1963 they used a thicker mirror , this is an NOS 1960-1963 GMC mirror assembly with the cast 1960-1962 Arm . Its white for GMC , Chevy mirrors are black. Notice three screws around the stem. Then 1964-1966 has this mirror , thinner design , only one screw and 2 rivets around the stem. The center stud came back in 1967 and up trucks. The Rectangular mirror was sold as an accessory to mount on the same arm as the round and was offered as a bigger mirror if the owner wanted. There's some controversy that some of the years I've posted on the round offsets snuck into other years. I'm stating what I've found from NOS parts and number applications and original trucks I've had or seen.
04-04-2017, 10:19 AM | #424 |
Rollin' Old Skool
Getting ready to put my '66 back on the road, & I believe we've decided to pull the 327 engine for some changes. While it's out, I'd prefer to change the color from orange to a more factory correct green. I'm curious what the current consensus is on the correct (I know there's no 100%) shade of green? Upon doing research here on the forum, I've read about the Alpine green being a bit too light & Ford green possibly being the closest. I also read about a Buick green possibly being a close match. Lastly, I saw where a NOS green paint was sprayed out for comparison, but even it was debated as to whether it needed tinting a bit. I'm not sure if that ever took place to get a better match or not. Any updated info on this subject is greatly appreciated!
04-04-2017, 11:10 AM | #425 |
Thanks for clearing up the mirror question for me 60-66, hoping I have the right one on my 65. I'll be checking when I get home.
