01-17-2017, 09:01 AM | #1 |
SBC vs BBC motor mounts
ok I've read on here before that something with the mounts is different on a small block vs big block truck.
We are converting on 79 C-30 from a factory 350 to a 454. So of course I have everything off the small block, since it was in the truck. I also have the following of the 454, which was in a 1978 c-30: - Clamshells on motor - frame stands - motor mounts. So which is specific to the big block? |
01-17-2017, 11:10 AM | #2 |
Re: SBC vs BBC motor mounts
If I remember correctly,it's the frame stands.
Been a while for me! I did this to my 82 in 1990! Mike. |
01-17-2017, 11:23 AM | #3 |
Nothing. The rubber mounts are stiffer but small block will work. I've swapped many small to big and didn't change a thing.....the difference is between car and truck, the clam shells are different.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-17-2017, 05:32 PM | #4 |
I just pulled mounts from an 85 3/4 ton big block. The frame stands have a slightly different profile then the small block ones. I also pulled mounts from an 87 1 ton with a big block and they are identical to the 85 3/4 ton big block ones.
01-17-2017, 07:19 PM | #5 |
There's some information on the differences in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=712655
In most cases you won't run into any problems unless you are trying to run something that is already a tight fit....like Hooker 2455 headers. In this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=713218 Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
01-18-2017, 01:08 AM | #6 |
I swapped a 454 in place of a stock 400 in a 79 1/2ton suburban. The only issue was I had to use a shorter fuel pump then the stock 454 truck pump. IIRC it was for a 70 monte carlo with 454.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
01-18-2017, 08:14 AM | #7 |
so that's 2 votes for frame stands, 1 for clamshells, and 2 for nothing.
no wonder this is so confusing. I thought I remember reading somewhere that whatever BBC part you need makes the engine site approx. 1" higher than if you had used SBC mounts |
01-18-2017, 09:00 AM | #8 |
It followed me home?
This
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-18-2017, 09:57 AM | #9 |
There are many different profile clam shells. There are taller clams for some big blocks than others. I know because I used Suburban big block clams in a truck and it smashed the fuel pump on the 454. GM made the clams specific for both the engine AND the chassis it was going in. That being said, it is rare that any clam won't get the job done. Use all of your 1978 parts and you will be fine.
01-18-2017, 10:18 AM | #10 |
Yes they are different. I believe the BBC raises the engine up alittle
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
01-18-2017, 11:47 AM | #11 |
the rubber mounts on the frame are the same and are interchangeable. the metal mounts on engine will work both ways but are taller on one than the other.
01-19-2017, 11:16 AM | #12 |
I found this info at GMPartsWiki.com:
79 C10,20,30 BRACKET, ENGINE MT. (aka clamshells) for small block is P/N 334601. For a 454, the P/N is 334605. Frame brackets appear to the same for small block and big block in C30 truck. http://www.gmpartswiki.com/getpage?pageid=59067
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-19-2017 at 11:43 AM. |
01-29-2017, 12:06 AM | #13 |
The rubber mounts are different for a small block and big block on how they bolt to the frame stands, that is the only difference. Both style of engines share the same two upper bolt locations, the lower hole location is what's different. The lower mounting bolt on a small block mount is on the outer edge (off center), the lower mounting bolt for a big block mount is in the center. The spacing of the upper bolts to the lower bolts is also different between the two mounts. You can use either mounts if your frame stands have both sets of holes. As for the clamshells you can use ones that came off of a small block or a big block and have no problems. Look at the back of the clamshell that is towards the block when bolted on to the engine. If the triangle is facing out to the block there needs to be a spacer plate inbetween the clamshell and the block, if the triangle is indent away from the block no spacer is needed. The spacer usually has a support rod hooked to it going to the transmission or transfer case. Using the spacer with the clamshell with the triangle facing out to the block puts the crossbolt at the same heighth as the clamshell with the triangle facing away from the block. that's why one clamshell is shorter than the other, the spacer makes up the difference.
12-15-2023, 12:10 AM | #14 | |
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
