Old 01-17-2017, 04:09 PM   #1
Ramiro0727
Dash Cluster
I'm almost done wiring up my son's truck with a new wiring harness from American Autowire. Today I changed his temperature gauge on his dash cluster. When i took it out the cluster to replace the wiring. I cut some wires that were attached to the cluster. Would I have to reconnect this wires back up to the new wire harness? His original wire harness was like a rat's nest. i think that's why they added the wires on back of the cluster to make some of the gauges work. Can somebody tell me if the back of my cluster looks okay and if I can remove those wires that are attached.
thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 01-17-2017, 04:15 PM   #2
dfwright
dfwright's Avatar
Re: Dash Cluster
It looks like your printed circuit has been hacked up. If you remove the external wires, you might need a new circuit board to connect the gauges through the standard wiring connector. The AAW harness will expect to connect through the standard wiring connector, with an intact printed circuit
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-17-2017, 04:18 PM   #3
dfwright
dfwright's Avatar
Re: Dash Cluster
This is what the printed circuit should look like.
Old 01-17-2017, 04:33 PM   #4
Ramiro0727
Re: Dash Cluster
Dfwright after I looked at the printed circuit . I was thinking the same thing. Looks like I will be ordering a new printed circuit. Thanks for your help.
Old 01-17-2017, 07:32 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Dash Cluster
Printed circuit is cut off at the two bottom gauges. Buy new one and everything should be fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-17-2017, 07:40 PM   #6
demian5
demian5's Avatar
Re: Dash Cluster
If the truck harness is butchered, you may have to hook it back up like it was or fix the problems. A new circuit board may not fix it.
Oh and add a ground wire between the cluster bolt above the speedo and the body of the truck.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-17-2017, 08:22 PM   #7
Ramiro0727
Re: Dash Cluster
Demian5 I installed a new wiring harness. Just tying to button everything up . So looks like i need to replace the circuit board to make it work correctly.
Old 01-17-2017, 10:21 PM   #8
BrianG
BrianG's Avatar
Re: Dash Cluster
Do you have the Classic Update kit or the Stock Replacement style. If you have the Classic Update then you will have to change from the amp guage to a volt guage. This will require rewiring how the circuit board attaches to the gauge so you may want to just use what you have and run wires to the other disconnected guage. It was probably disconnected for a reason and you'll have to diagnose that first.
BrianG is offline   Reply With Quote
Old 01-17-2017, 10:42 PM   #9
Ramiro0727
Re: Dash Cluster
BrianG I have the American Autowire Power 13 kit.
Old 01-17-2017, 10:57 PM   #10
BrianG
BrianG's Avatar
Re: Dash Cluster
Hmmm guess I don't know with that kit. Might be worth a call to AAW. I've heard their customer service is really good.
Old 01-17-2017, 11:06 PM   #11
Ramiro0727
Re: Dash Cluster
BrianG there customer service is great. I have emailed them a few times asking them some questions and have always answered my questions. As a matter of fact I will be emailing again. One of the wires on the kit is mislabled I think. I can't find the 12V ignition wire. It's labeled ignition feed. I need the power wire for the distributor.
Ramiro
Old 01-18-2017, 01:31 AM   #12
88Stanger
88Stanger's Avatar
Re: Dash Cluster
I rebuilt my cluster and installed a new circuit board and a new complete wire harness. But here is a question i have. Did you remove the printed circuit board wire plug? This would be the large plug that goes into the big hole on the back. Sorry if i am going overboard, just not sure if you know what i am referring about. This plug brings all the power and wires to the board and out. It really makes me wonder if they removed the plug and instead just direct wired the gauges.
88Stanger is offline   Reply With Quote
Old 01-18-2017, 01:54 AM   #13
Ramiro0727
Re: Dash Cluster
88Stanger yes the cluster wiring plug was plugged in when I took it off. I ended up making a new plug for the dash cluster. I didn't like the looks of the old one.
Old 01-18-2017, 02:02 AM   #14
Ramiro0727
Re: Dash Cluster
Here is my new cluster plug.
Old 09-10-2017, 11:28 AM   #15
Swedchevy67
Re: Dash Cluster
Hi!
I just spotted you picture and that's what I am planning to do myself.
Did you just replace the wiring from AAW in the same order and collor?
Swedchevy67 is offline   Reply With Quote
Old 09-11-2017, 12:50 AM   #16
Ramiro0727
Re: Dash Cluster
Originally Posted by Swedchevy67 View Post
Hi!
Swedchevy67 yes I replaced the wiring using the wiring from the AAW in the same color and order.
Ramiro
Old 09-11-2017, 01:08 AM   #17
Swedchevy67
Re: Dash Cluster
Ramiro
With no problems?
Old 09-11-2017, 01:11 AM   #18
Swedchevy67
Re: Dash Cluster
I notice that youR nr 12 is empty? In mine I have nr 5 empty. I belive nr 12 is ground cable.
Old 09-11-2017, 10:06 AM   #19
Ramiro0727
Re: Dash Cluster
Swedchevy67 I followed the wiring diagram someone posted on here. Yes I believe I left nr 12 empty.
Ramiro
Old 09-11-2017, 10:26 AM   #20
LockDoc
The Older Generation
LockDoc's Avatar
Re: Dash Cluster
Ramiro
I'm not out in the shop right now to check, but if nr12 is a ground wire it would probably be this one that the arrows are pointing to. It goes through part of the old harness.
LockDoc
Leon
Old 09-11-2017, 12:23 PM   #21
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Dash Cluster
No. 12 is the battery gauge positive wire in the stock harness. It mates with no. 1 in the harness plug for the other terminal ( remember the word Swede).
Name:  cluster connector with gauges.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-13-2017, 12:00 AM   #22
LockDoc
LockDoc's Avatar
Re: Dash Cluster
The one in my picture should be #7 then....
LockDoc
Leon
Old 09-13-2017, 12:26 AM   #23
Ramiro0727
Re: Dash Cluster
With no problems?
No problems at all.
