01-18-2017, 06:48 PM | #1 |
Dash Pads
Anyone used Summit Racing's dash pad? That seems to be the cheapest I've found. It's either that or find a decent used one and put a cover on it. I can't see spending over $320 for one, can't afford that.
01-18-2017, 07:01 PM | #2 |
Re: Dash Pads
I put one of there urethane dash pads in my 78 looks good and fit nice for the money you can't beat them they are from dashes direct
01-18-2017, 08:29 PM | #3 |
Re: Dash Pads
Thanks, I should have said the urethane was the 1 I was looking at, $227. I can't find a used one around here that I could put a cover on. They are a $100 for them.
01-18-2017, 08:31 PM | #4 |
Re: Dash Pads
I wish I could because I need the insert for a/c also.
01-20-2017, 05:36 PM | #5 |
Re: Dash Pads
Pm
01-20-2017, 05:40 PM | #6 |
Re: Dash Pads
We have a vendor on here now who reproduces them-better than anybody else from reviews I've read too on other forums. cheyennepickup is his ID-I plan on trying one of his 81-up Dashpad's....prices are about $339 if I recall.
01-20-2017, 06:25 PM | #7 |
Re: Dash Pads
A member on here PMed me, he has a perfect 73 to 78 I think he said. I was thinking they had to be 81 to 87, am I right on this? Mines a 84.
01-20-2017, 09:13 PM | #8 |
Re: Dash Pads
I believe the only difference is, is that on the 80's, there the cutout for the vin plate on the left side by the windshield. The later models, there is no cutout. Just not sure when it started.
I hope I'm right on this info. Maybe someone else will chime in, if this isn't right.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-20-2017, 10:25 PM | #9 |
Re: Dash Pads
For some reason I was thinking they were different around where the cluster cover goes. I may be wrong, happens alot here lately.
01-20-2017, 10:30 PM | #10 |
Re: Dash Pads
No, I think you maybe right.
01-21-2017, 10:24 AM | #11 |
Re: Dash Pads
I got a dashes direct dash pad for my '85 from LMC other than some minor trimming, it has held up well and looks very factory. I painted it with Colorbond to match my interior. You can see it in my thread located in projects and builds the 73-80 cab and the 81-87 cab are identical. If it were not for the different instrument clusters, you could use interchange dashes with no modification. If you are changeing your instrument cluster and dash, it should be a bolt on application.
01-21-2017, 10:40 AM | #12 |
Re: Dash Pads
I bought a new one for my 74 from Summit ,have not yet installed it but it looks great ,good quality .
01-21-2017, 11:37 AM | #13 | |
Re: Dash Pads
01-21-2017, 07:15 PM | #14 |
Re: Dash Pads
My 82 has a cracked, cheesy aftermarket plastic cover, and I have been trying to determine which way to go. Found these comments about the OER urethane pad sold by Summit:
https://www.summitracing.com/parts/o...31898/reviews/ Comments range from "fit like OEM" to "terrible fit". So what' a guy to think??? BTW, how do the vinyl and urethane pads differ?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-28-2024, 12:30 PM | #15 |
Active Member
Re: Dash Pads
02-28-2024, 06:37 PM | #16 |
Re: Dash Pads
03-09-2024, 09:35 AM | #17 | |
Re: Dash Pads
Jeff's bowtie's
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
