Old 01-18-2017, 05:11 PM   #1
'68OrangeSunshine
'68OrangeSunshine's Avatar
Breaking Valve Springs
This same gripe came up 2-and-a-half years ago:
'68 L6 292 -- Burnt Valve, Brkn Rings?
http://www.67-72chevytrucks.com/vboa...d.php?t=636925
Same truck, same signs and symptoms, different cylinder.
Subject is a 292 L6 in a '68 C/10 Stepside, rebuilt in 2005, under 40,000 SMOH. Engine is original to the truck, but rebuilt after being stored 25 years.
Last time after some diagnosis, we found a broken exhaust spring on Cyl #4. This time the Vacuum gauge is reading about the same [9.5" Hg w/slight bounce] where 17"Hg Steady would be the nominal indication at operating temp. RPMs also dropped. Basically, it's a 5 cylinder.
I ran a Dry Compression Check:
1] 0
2] 136
3] 135
4] 145
5] 128
6] 130
I did not run a Wet check since I found the source in Cylinder #1. Cylinder #4 only looks good since that was the one replaced in July 2014.
One broken spring is a fluke. More broken springs is an alarming trend. This time I will replace all the valve springs and set valves again.
Plug from #1 was smudgy, all others had normal ash.
New springs are on order. Also need to get valvespring compression tool = modified wonderbar. And fresh rubber umbrella seals.
Question is What causes valvesprings to break? This never used to happen in my other Chevy engines, either L6 or V8.
'68OrangeSunshine is online now   Reply With Quote
Old 01-18-2017, 08:45 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Breaking Valve Springs
Was there a mix and match of internal engine parts in this rebuild?? Harmonics of a poor balance job will cause valve springs to fail. Bought a 350 in a Blazer years ago that 'just had a rebuild' Was fresh but the moron decided a 305 crank was a fit replacement for a 350 (+.040) engine. Was VERU noticable vibration at 2800rpm (cruising speed) and the Z-28 valve springs on the 441 heads would pop about 2 a year RANDOMLY. When I pulled it apart and found the 305 cast crank did some research. Some crank casting #'s are used in both the 05 and 350 BUT The same number and same stroke is all they have in common! The two have just over 100 grams difference in bob- weight in the balance.
I bring that up just in case someone made serious swaps in internals during this rebuild and didnt have the assembly balaced,, it WILL cause harmonics and all sorts of random engine problems.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-18-2017, 11:17 PM   #3
'68OrangeSunshine
Thanks, Marv.
I thought my machinist was meticulous about balance and parts quality. It was about 14-15 years ago.
When the first spring broke, I brought it back to him and he found a like-sized replacement 'good, used' at no charge. We thought it was a fluke at the time. He asked if it was a Z-28 type. I didn't think so only stock. But now reading in Leo Santucci's "Chevy 6 Cylinder Power Manual'' he says ''Z-28 Chevy V8 springs with stock retainers, keepers, and stock length valves can be used on hot street cams up to .480" lift with flat tappet or hydraulic lifters.'' I would have remembered if I had Z-28 springs and even bragged about it if I knew.
Build was a '68 292 block, bored .030 over, with Badger pistons [cast], OEM rods, ARP fasteners, Intake valves are 1.84'' [stock for a V8 307, where 1.6'' is stock fr a 292], Exhaust valves are the stock 1.5". New valve springs [I thought]. Stock 12-lobed '68 292 crank. Crane 260H cam. Rhoads variable lift lifters. Mellling hi-volume oil pump. Centerforce II clutch. He rebalanced the pressure plate. '68 292 11" flywheel. Offy intake, Edelbrock 500 CFM 1404 carb. Clifford headers. Cross-over dual exhaust. Now has HEI. SM465 4 speed, to an Eaton Posi in a 12-Bolt Corp rear.
Talking to one of my local [non-chain] parts guys, he said if one spring goes, they should all get replaced. That's what we'll do once all the parts get in.
Old 01-18-2017, 11:27 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
How much lift on the cam? Stock valve springs are only good for .450. After that you have to go a step up. Z/28's are good for .500 and tend to create a little to much open pressure. Those that have used them haven't complained of flat cams that I'm aware of.
Old 01-18-2017, 11:47 PM   #5
'68OrangeSunshine
Crane 260H.
From the Cam card -- Lift
Intake at valve=.498"
Exhaust at valve = .530"
Now I'm wondering if I have the wrong value springs on order? I just specified stock 2.1090" free height.
Old 01-18-2017, 11:53 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by '68OrangeSunshine View Post
Crane 260H.
The Z/28 springs are the same height if I remember right. And never mind, I just looked back at my power manual and it says the z/28 springs are good to .600 lift.
Old 01-19-2017, 12:11 AM   #7
'68OrangeSunshine
I'll have to take my broken valve spring into Don's Hot Rod Shop, and ask if it's a Z-28 type.
Didn't think so.
Old 01-19-2017, 12:12 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
Didn't think so.
I doubt it, unless you have something worse going on...I think it's a case of to much lift on stock springs.
Old 01-19-2017, 12:13 AM   #9
'68OrangeSunshine
Maybe I should get Z-28 springs then?
Old 01-19-2017, 12:15 AM   #10
TJ's Chevy
TJ's Chevy's Avatar
Wouldn't hurt to try, I'd wait for some of the other folks here to chime in and see what they think. I may be over looking something.
Old 01-19-2017, 12:21 AM   #11
'68OrangeSunshine
I thought I had a weather window Thursday to work on my engine outside. Doesn't look like there's gonna be much good weather until next week.
We'll be getting what just clobbered your area.
I'll have to work an 11 day week starting Saturday, so this project will have some time to collect parts and knowledge yet.
Old 01-19-2017, 11:20 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Yeah, we're getting slammed with rain as I type this. Glad I have my 66's cab under a small car cover and the chassis in the garage.
Old 01-19-2017, 01:38 PM   #13
suville
suville's Avatar
You might consider giving Tom Lowe (12bolt.com) a call he's pretty savvy to chevy sixes and very helpful. Building a 292 myself with Toms assistance waitin on my head now.
suville is offline   Reply With Quote
Old 01-19-2017, 02:17 PM   #14
'68OrangeSunshine
Are you going with Lump Ports?
Well I don't have Mr Lowe's number, but I could post this same query on www.inliners.org I guess.
Larry Page was my mentor on the build-up, back in 2002-05. I should ask him.
Old 01-19-2017, 02:35 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
Here's Tom's number 1-319-310-6920.....this is not his business number. His business number is on his sight. Just tell him Thomas Mccauley gave you this number. He may remember me, I talked with him many times and bought a number of parts from him for my 292 as well. We talked so often that he gave me his personal cell. haha He tends to answer that more often....I should give him a call again. Been quite awhile. He does use both numbers for business though.
You could also PM Larry aka Twisted6 on this forum for info.
Old 01-19-2017, 07:48 PM   #16
'68OrangeSunshine
Thanks, TJ. I picked up a dozen Sealed Power stock springs today. Jay at Don's Hot Rods [our local hi-perf 'candy store'] said the Crane double coil springs specified on my cam card would require machining into the head to fit. No way.
Waiting for parts to arrive timed out my maintenance schedule today.
Old 01-19-2017, 09:37 PM   #17
suville
suville's Avatar
Yes its getting ported, the full head deal, started out with .040 over sealed power pistons to rebuild stock and changed my mind so Ive ended up with some internal parts I wont use, learning curve on a six.
Old 01-19-2017, 09:51 PM   #18
PGSigns
PGSigns's Avatar
Take the head to a qualified machine shop and get it set up for the cam in the engine. Just shoving a set of springs in it is not going to get you a good setup. Need the installed height checked on the springs and the amount of lift before coil bind. The pressures need checked and the installed height needs to be checked on the head and the head cut or springs shimmed to get it all correct.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-22-2017, 01:51 AM   #19
'68OrangeSunshine
Would I get the same indications from a collapsed lifter? Even Zero compression in #1 cylinder?
PG-- I'm trying to stay out of the machine shop for the present. This isn't a new build, it's been running good for 12 years, now. [Except for breaking a spring in July of 2014]. All that was done when it was first set up. The replacement springs I got are the same kind as the others. The discussion drifted into the possibility of upgrading to Z/28 springs or the double-coil types spec'd on the mfr's cam card. Those would require machining into the head to use. I will have to check installed height.
I think it's early for a rebuild at 40,000 on a 292. My last one ran for 250,000.
Old 01-24-2017, 12:01 AM   #20
GRX
GRX's Avatar
Jimmy
^^ that x100. This is especially important when working with worn valve seats & valves. Think of distances. More to setting up head/s than many consider. A lot to be said for having all 12 springs working at the same pressures. Not only at the valve, the lifter and cam too.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 02-04-2017, 11:52 PM   #21
'68OrangeSunshine
Fixed.
New valve springs and umbrella shields.
Runs good.
Old 02-05-2017, 11:21 PM   #22
TJ's Chevy
TJ's Chevy's Avatar
What springs did you end up going with?
Old 02-06-2017, 08:44 PM   #23
'68OrangeSunshine
Sealed Power from the local hot rod shop. Four Bucks apiece [ X 12]. Could'a been cheaper at rockauto, but I like to support my local candy store venders.
Can't access the p/n right now, as the whole rig is at the tire shop as I have an unknwn hardware fastener/s in my Drivers' Side front tire. Also getting rotated.
New springs are kinda crispy. Like an apple. Lots more direct horsepower applied. Some hickups when cold, mostly singular. A fine-tuning will be in order later. Right now, it's tires time. Then brakes.
Wait was so long on an early Monday afternoon, that I walked home. Waiting for a call back from mgr.
OK-- There it is.
Gotta go.
Old 02-10-2017, 08:23 PM   #24
'68OrangeSunshine
Sealed Power p/n: SP VS 521 [x 12].
Excellent fit and exact duplicate of other springs. Hopefully not from a brittle batch. Running like a top.
Old 02-11-2017, 12:40 PM   #25
GRX
GRX's Avatar
Sealed Power are good springs. Have rebuilt hundreds with them. Exact same as most other brands just in a different box.
Point to ponder .... how many cycles between open & closed pressures has a set of springs seen? Quite literally millions if the engine has a decent amount of miles. Not saying this is your case. A shame how often they are re-used in rebuilds.
