01-19-2017, 08:32 PM | #26 |
Diggin The SquareLife
Re: HELP Please 85 GMC body fit on 74 chevy frame
cut the front part of the frame rails at an angle so the newer brackets will slide on
01-19-2017, 10:55 PM | #27 |
The better way is to cut the newer brackets, instead of hacking the frame up. if you search you can find the pictures of how the brackets need to be cut.
04-25-2018, 02:44 PM | #28 | |
04-25-2018, 07:51 PM | #29 |
I’m putting a 84 onto a 76 frame, pictures of how to cut the bumper brackets instead of the frame would be helpful, I will cut the frame if I have too but the brackets seems easier.
04-25-2018, 08:46 PM | #30 |
use the body mounts for the frame vintage NOT the donor body .
and 81-up frame horns up front are just 45* slash cut and top sticks out and bottom is cut back as the cut goes . sorry i dont have pics . if i was to modify 81-up frame brackets for the ends of the frame i would cut the top off first and leave the side . but i have not ever done that as my area is rust belt and 73-80 frames are super hard to find so i only tend to play with 81-up stuff.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
