02-19-2017, 07:22 PM | #276 |
Re: Show lowered 88-98 trucks
03-05-2017, 02:33 PM | #277 |
My 1992 C1500, bagged on 20 inch Ridler 695's. Lays currently crushing the exhaust y pipe. Soon to be remided and it will lay flat.
03-15-2017, 02:44 PM | #278 |
Nothing fancy about mine other than she is a 1988, got her in 1990 and slammed it.
Nothing special. Don't have the tonne cover on right now. Last edited by 88lowrider; 03-15-2017 at 02:49 PM. |
03-15-2017, 06:19 PM | #279 | |
What is the specs on your lowering? 4/6??
03-15-2017, 07:18 PM | #280 |
This came down 6" by a outfit that used to be in Gresham Oregon called Charley's Drop Shop.
They modified the lower A frames and not sure what was done in the back other than they had to notch the frame too. This allowed better control of adjusting the caster and camber. She does not eat tires like the drop spindle lowered trucks. That I like ! The cross frame under the motor, 3" clearance. If the tire comes off the rim, she is on the asphalt. |
03-15-2017, 07:28 PM | #281 |
Thanks for the info. It has a really good stance
03-15-2017, 07:37 PM | #282 |
Thanks Bill.
I ended up using some Monte Carlo shocks in the front and not sure in the rear which were air shocks. I never did pull the rear springs as the overload spring needs to be changed. We have a place up in Portland Oregon called Oregon Spring. I give them what measurements I have and they re-arch the overload spring. I started out and was going to put a Air Lift (bag in a coil spring) setup in the rear but never did. I really need too as if your going pack anything around, she will come down and pumpkin will hit the bottom of the truck bed. Done that a few times ;-/ I remember being a little on the tipsy side heading back home from a friends house and forgot the 30mph curve. I hit it about 70mph and Everything in the cab was up against the door and window, including me. She went around that corner like she was on rails. The front shocks were some trick gas shocks. I can't find the book on her since the move and in that book, I wrote down what shocks I used. Hope to find it but even if not, they can take those off and match them up. She still rides like a car too. Helmar |
04-15-2017, 03:29 AM | #283 |
my 92 2/4 drop
05-04-2017, 05:59 AM | #284 |
Update: got the AR torque thrust wheels on it along with the Nfamus control arms also got rid of the hideous exhaust tips, a few more changes and it'll be ready
05-04-2017, 04:39 PM | #285 |
05-05-2017, 09:55 PM | #286 |
05-05-2017, 10:41 PM | #287 | |
Do you know the backspace on the TT wheels? Are you running staggered?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
05-06-2017, 01:34 PM | #288 | |
Rollin' Old Skool
Good question; I liked those billets!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
05-06-2017, 01:45 PM | #289 |
Rollin' Old Skool
On my old '93 with 5/8 drop, I had an exhaust shop make a new one & tuck it up higher.
06-04-2017, 12:31 AM | #290 |
details on wheel tire package ...btw CLEAN
94 EXTENDED CAB 64 CHEVELLE |
06-06-2017, 12:40 PM | #291 |
My 1997 C3500 with a 5.9L Cummins, work in progess
I've got a 1997 C3500 Dually with a belltech drop spindles. Anyone else had issues with brakes pulling one way or other? There is a large gap between top of brake caliper and the spindle on my truck, and belltech sent me a second spindle and it measures the same, and looks the same with new caliper installed. (large gap at top, only on drivers side) This is causing caliper to twist, wear brakes uneven, and pull to the left.
======================= 1997 C3500 5.9L Cummins Conversion 1989 Caprice Classic 5.3L Turbo 4L80E 1967 Chevy C10 6.6L Duramax Conversion In Progress http://www.lt1swap.com ======================= |
11-12-2017, 04:39 PM | #292 |
My 96' 4.3 pulling my 64' Datsun 320. Both trucks flooded last year. The battery was disconnected so the electrics seemed fine after I let it dry out a few weeks. Looking to pull the 4.3/4L60 and drop in an LS/trans once I get the house finished up.
11-12-2017, 05:56 PM | #293 |
That’s awesome you have a Datsun! I’ve been wanting to do a 320 for a few years now.
11-25-2017, 12:21 AM | #294 |
Update on my 88. 17x8 and 17x9 Eagle wheels, with 255/60 and 275/60 17s. Black truck is my old 90, Dropped with spindles, and dropped springs. The springs had 1 coil cut. Ended up at a 6" drop. 6" steel wheels, forgot tire sizes.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
11-25-2017, 09:20 AM | #295 |
Love the look & stance on your bule 88!
01-08-2018, 06:17 AM | #296 |
My 1990 454 ss
01-08-2018, 06:29 AM | #297 |
One day.....
DZL1. Bertha build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=733306 '72 C10 short bed. Bessie (traded) '93 C3500 CC Dually. Bertha (traded) ‘96 C1500 ECSB. Black Beauty '89 C1500 RCSB LS swap. Black Bean '06 Silverado CCSB Ghost (Wifes Truck) '12 GMC Terrain V6. Titanium Bling (Wife’s Daily) ‘14 Chevrolet Cruze. Raspberry (Daughters Ride) '99 Jeep Wrangler. Road Hog (Sons Ride) |
01-15-2018, 01:58 PM | #298 | |
Re: My 1997 C3500 with a 5.9L Cummins, work in progess
Hey bud. You might have a bent brake caliper bracket. Had a problem like that with a montero sport. |
02-03-2018, 05:09 PM | #299 |
Not mine. But it pops up everytime i look up pictures on google.
Anybody know the truck |
02-03-2018, 07:32 PM | #300 |
what drop and tire size ? btw clean !!!!
