Old 03-05-2017, 01:24 PM   #51
7D2N
7D2N's Avatar
Re: My winter project
Originally Posted by craneboy72 View Post
Where u able to find the rubber part that was stapled to the metal of the dust seal and do u have any pics installed
Craneboy, I got the kit from LMC and used the assembly manual for help. This is how they turned out.
7D2N
Just for the fun of it
7D2N is offline   Reply With Quote
Old 03-05-2017, 02:35 PM   #52
craneboy72
craneboy72's Avatar
Looks great thanks for taking the time and posting all the pics
craneboy72 is offline   Reply With Quote
Old 03-05-2017, 07:51 PM   #53
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Those things are kind of a pain to install.
Tom Vogel is offline   Reply With Quote
Old 03-19-2017, 08:40 PM   #54
7D2N
7D2N's Avatar
I found seat support patches from a truck to use. The floor mounting braces look close but the mounting holes are a bit different, I need to cut the blazer floor and move the braces to the new patches.
Old 03-19-2017, 09:03 PM   #55
lks dcvn
lks dcvn's Avatar
You are getting in the fun part of the build. Once you have the mechanical in good enough shape to drive it - you can repair the cosmetic and rust as you go.
Nice work so far!
lks dcvn is online now   Reply With Quote
Old 04-27-2017, 10:12 PM   #56
7D2N
7D2N's Avatar
Now the front is off and I can see what I'm working with, the sway bar and these brackets are going. I plan to get a stock look with an minor lift. Anyone know if this harness for the smog pump.
7D2N
Old 05-01-2017, 09:42 PM   #57
7D2N
7D2N's Avatar
I got the windshield header today. I'm checking measurements and it looks pretty good so far and a lot better than what I have now.
Old 05-02-2017, 07:55 AM   #58
lks dcvn
lks dcvn's Avatar
Cool - new parts - will be watching you work with the header piece - needed it in the past and sold the truck before that part came out.
Some light reading for another member who used the same parts and found some challenges using them.
http://67-72chevytrucks.com/vboard/s...d.php?t=655031
Not sure if the parts have changed any since that post is from 2015.
Keep us posted on your progress with the new header pieces.
Old 05-02-2017, 08:08 AM   #59
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I do not believe the smog pump had any electric hookup. I also believe that Morgan county is smog exempt for your truck. Am I wrong on that?
Old 05-02-2017, 09:00 AM   #60
69-72
69-72's Avatar
I'm not sure if you saw my thread on my experience with installing one of these but bolt up your visors to make sure everything lines up, I had to move some of the nut serts a significant amount to have the visors sit right.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 05-02-2017, 08:05 PM   #61
7D2N
7D2N's Avatar
Tom the blazer was smog equipped, just trying to figure out what and where the harness went. I think I have the AC harness checked out.
7D2N
Old 05-02-2017, 08:27 PM   #62
7D2N
7D2N's Avatar
69-72 I checked your thread many times before I went this route and thank you. I think this is my best way to go. I have been carefully checking measurements on my original and I put the visors supports on with bolts and holes seem to be spot on. Then again it's just 5 parts out of the box right now.
7D2N
Old 05-13-2017, 07:25 PM   #63
7D2N
7D2N's Avatar
Windshield is out, I'll have my work cut out for this and really test my skill level.
Old 06-11-2017, 12:53 PM   #64
7D2N
7D2N's Avatar
I got the mock up done so now start welding together. 69-72 I had to move the mounting holes for the visors also. Thanks for sharing your information it help me alot.
7D2N
Old 06-11-2017, 12:57 PM   #65
7D2N
7D2N's Avatar
more.
Old 06-11-2017, 01:15 PM   #66
69-72
69-72's Avatar
Looks good. Triple check everything, hard to change later.
Old 06-11-2017, 07:17 PM   #67
cleszkie
cleszkie's Avatar
Cutting the windshield frame off is a BIG leap of faith when you first do it. But once you have it repaired you will feel great. I nearly crapped myself when I stepped back after cutting mine off. But after grafting the donor frame back on, I felt a great boost of confidence.
cleszkie is offline   Reply With Quote
Old 06-12-2017, 09:24 PM   #68
7D2N
7D2N's Avatar
It went better than I was expected, I knew where the new parts were suppose to be but just a little scary to start chopping.
Old 07-25-2017, 08:07 PM   #69
7D2N
7D2N's Avatar
Finished the windshield header and the top is bolted down to start floor work. I will say it's a bit time consuming but will work great.
Old 07-25-2017, 08:11 PM   #70
7D2N
7D2N's Avatar
more...
Old 07-25-2017, 08:15 PM   #71
7D2N
7D2N's Avatar
and some more.
Old 07-29-2017, 08:45 AM   #72
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I got mine at GMC Pauls
http://www.gmcpauls.com/
Kind of a pain to put together.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-30-2017, 08:21 AM   #73
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
The progress is looking good!
Old 11-06-2017, 08:28 PM   #74
7D2N
7D2N's Avatar
Slow progress but still moving along. I have the old lift out and working on a new 4" with rear blocks, the old springs are shot but found a set of rear that will replace the ones if have.
Old 12-06-2017, 11:24 PM   #75
7D2N
7D2N's Avatar
I worked with two sets of rear springs replacing broken leafs and making a good set, rear blocks and springs for the lift are set.
