03-13-2017, 11:53 PM | #1 |
Active Member
Re: Complete build change. Lifted 2wd
I'm liking the stance! What year control arms spindles and rotors did you use? All people told me to do to lift my c20 is get one ton springs.
1972 GMC C2500 Tow Rig project 1972 C10 Air Bag project 1967 C10 Drag Truck project 1967 GMC Patina Special project 1968 C10 I have no clue what to do with project 1969 GMC C6500 I wish I had more money project 1986 K10 I have too many damn projects |
03-14-2017, 11:23 AM | #2 |
Thanks! that was the common until a board member found a way to put 88-98 chevy lift spindles on. It requires 1967-87 3/4 ton lower control arms, 88-98 upper and lower ball joints, 88-98 spindles, bearings, rotors, calipers etc...and if you plan to run a sway bar, the tie rods have to be moved to the top of the spindle but keep in mind what wheels you're running as this puts the tie rod really close to the lip.
03-15-2017, 11:35 PM | #3 | |
Active Member
03-16-2017, 08:48 AM | #4 |
Cool build! I'm strictly a member of the drop spindle crowd and didn't even realize they made lift spindles like that. Looking forward to seeing how this thing turns out.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
03-16-2017, 04:17 PM | #5 | |
Gettin exciting. gonna be swapping the body over soon so i can actually see how tall it sits. |
03-16-2017, 06:43 PM | #6 | |
Active Member
03-16-2017, 07:03 PM | #7 |
Oh that makes sense. Ya i believe the suspension is all the same but sounds like if youre gonna lift it id stay 4x. way more capable. I wanted to go 4x4 but couldnt seem to locate a frame so the 2wd lift is goin down
Tags |
2wd lift, 67-72 chevy, lifted, lifted 2wd, ls swap |
