#76 |
![]() Join Date: Mar 2004
Re: 1972 Jimmy + 5.3/4L60E/NP205
Ens-3-1106r - trans mount
ens-3-1107r - t-case mount ens-3-4110g - body mounts
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
#77 |
![]() Join Date: Nov 2013
I'm using the Entropy radiator as well on my swap....do you have the part#s of the radiator hoses that you used...? thanks
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#78 |
I will look thru my receipts tonight and post up what I find.
#79 |
much appreciated...no hurry...thanks!
#80 |
Oreilly Part Numbers for the radiator hoses.
GAT - 22437 GAT - 21439 I know I had to trim one a little bit to make it fit, but other than that they work perfect.
#81 |
IIRC you mentioned moving the motor forward 2 inches....is there room to move it 3" ?
I finished my mount and I about to set it all in place... I bought some Energy Suspension universal poly bushings and sleeves.... Got the frame mounts bent up.....snug fit in the frame rails...... [ATTACH]1636626[/ATTACH
#82 |
I forget if mine was 2" further forward or not, but it sits pretty tight to my firewall. There is all kinds of room left up front though. I have Entropy with dual fans and I can "almost" still run my old clutch fan on the front if needed to. So there is that much room still.
#83 |
Nice build, just got done going through the whole thing looking for more gas tank pics. Also, great info for my future plans for an LS swap. How's the Jimmy doin?
1972 K5 Blazer 350/350/PS/PB From GA but live in Panama City, FL |
#84 |
Thanks, she is doing good. I think she turned over 2k miles since the swap and zero issues. Keep us updated on your swap. Don't hesitate to ask questions.
#85 |
Great build! Always enjoy getting motivation and ideas from others on here.
Are you running a factory console? Would you posting a few pics of the front seats? I was thinking of running those but recovering to look more original with no headrest. |
#86 |
Quick question for you. In post #30 it looks like you might have had to clearance the frame to fit the big Doug Thorley headers. Am I seeing things, or did these fit without modification? Thanks
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
#87 |
you are 100% correct. For whatever reasons, I needed to shave a sliver off the frame rail. They "fit" before I modified anything but it was a little too close for comfort so I shaved it down a bit.
#88 |
Nice build, I always go back to look at pics, just for the bling and shine
