03-25-2017, 06:37 PM | #101 |
Re: project "C10 Fever" (68 factory black 396 swb)
mocked up. holes drilled. assembled. now i just need to install all 10,000 bolts! it's a beautiful saturday, but i had to head to fresno to visit family so that will happen another day. i suppose that's the right priority... 🙂
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
03-26-2017, 01:27 AM | #102 |
That bed beds going to look awesome.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
03-28-2017, 12:03 AM | #103 |
03-28-2017, 05:31 AM | #104 |
The bed looks awesome, I just recently put mine back together and it sure does make for sore fingers tips by the end of assembly That is a lot of bolts !!
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
03-28-2017, 06:59 AM | #105 |
sub'd bad ass so far. good stance
03-28-2017, 11:07 AM | #106 |
Looking good Tim. I have a couple questions for you.
I recently picked up a wood bed for my project and want to paint the wood like you did and use either the stock strips powder coated like you or get the stainless ones from Mar-K. They are where I am going to get the wood. I have not seen any negatives from them other maybe the cost. but I don't have time to cut my own. What wood did you go with? Oak or Pine? What primer and paint did you use on the wood? Did you powder coat the rear bed rail that was once tack welded to the sides? and if so how are you replacing the welds? or are you not? Keep it up the truck is looking great!!! Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-28-2017, 11:39 AM | #107 |
The bed looks incredible!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
03-28-2017, 01:24 PM | #108 | |
thanks guys for the comments.
pine wood since i didn't care about wood color. pretty good quality, and kiln dried. i read the Mar-K test reports on their website and used 2 coats of POR-15 as a primer and then 2 coats of BEHR exterior latex for topcoat. i brushed everything on. i powdercoated the bed supports. i ground off the PC in the weld area, and plan on tack welding at the factory locations and then touching up with POR (it is a high gloss black and hardens similar to PC). i'm going to do the welding last after i verify tailgate fitment. one thing i recommend if going with this coating method is mockup the wood sections around the wheel tubs and mark/drill prior to coating. the POR dries VERY hard. i drilled the holes after coating and the bit splintered the wood around the holes. those areas get covered up, but still...
03-29-2017, 09:10 AM | #109 |
Still Learning
Your wood floor looks great!
03-29-2017, 11:28 AM | #110 |
thanks for the tips!
looks good keep it up!
04-12-2017, 08:02 PM | #111 |
Awesome truck build. I was looking to put 20's on mine and drop it but now I think i will go with 15's. I read the posts but didn't seem to find the info on the Drop, tires, and backspacing used. Do you mind reposting that?
Thanks, Jeff
1969 C10 = Red /Black 402 BBC, Holley Terminator EFI, 10:1 CR, Isky Roller Cam, Weiand Stealth intake, GM Serpentine Drive , Mechman 170 amp alt, Classic Air, Dewitt aluminum radiator with black ice coating, Dual Spal fans, G-body overflow tank, 700r4 trans, 12 bolt rear, 3.73 gears and Detroit Truetrac posi |
04-12-2017, 08:09 PM | #112 |
thanks for the feedback!
i posted most my info in this thread: http://67-72chevytrucks.com/vboard/s....php?p=7710662
05-01-2017, 02:51 PM | #113 |
GM Addicted
Truck looks good man. Wheel and tire combo is on point!
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
05-02-2017, 06:55 PM | #114 |
thanks!
very soon i'll be cleaning up the engine compartment. going to hide as much as i can without doing any cutting or welding. battery will go under the bed. i have a friend who is going to fabricate me a plate similar to the factory heater delete plates that will fit the a/c firewall. here's the look i'm going for. black engine bay, probably semi-gloss. not sure on the air cleaner just yet...
05-26-2017, 04:27 PM | #115 |
my birthday present finally arrived... woohoo!
05-26-2017, 04:30 PM | #116 |
installed the new battery tray so i can get the bed back on now.
05-26-2017, 04:36 PM | #117 |
started into the front end. my 8-year old expressed a serious interest in helping me on the truck for the first time. he did most of the disassembly. it was a pretty cool moment! the plan is to p-coat the core support, inner fenders, and a few other parts black.
also just bought one of the high hump original GM floor mats on ebay that a forum member shared. excited to see how it fits.
08-07-2017, 03:01 AM | #118 |
it's been a slow couple months. crazy job. busy summer. trying to get back to the front end. got a bunch of parts back from powdercoating. blasted the core support and inner fenders, working out some dings and dents.
found this on the core support. not sure what it means. also not sure why i posted it. seemed weird. it's midnight and i'm tired... added a speed warning setup to my choke delete cluster today too. plan on adding a tach at some point too if/when i can find a deal on the right parts.
11-13-2017, 01:53 AM | #119 |
Been too busy for the last few months to mess with the truck, but last night I had a work get together at my house and took advantage of having a few co-workers that could help me throw the finished bed back onto the truck. That gave me a little inspiration.
Just a few more tweaks to the wiring harness and then reinstall the bumper and tailgate and the back end of the truck will be done. I installed rubber pads between the bed and frame (1/4" I think), and looking at the body lines I think I'll need to install new cab mounts to true it up. Gotta love OEM parts. The bed I removed was a steel floor. I used cross braces and header panel from a donor wood floor bed. The clearances between the tires and the wheel wells are still 5/8" each, exactly what they were before the steel bed came off. Whew!
11-13-2017, 08:50 AM | #120 |
That is one good looking ride. Love the white lettering on the tires.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
11-21-2017, 11:56 PM | #121 |
choke delete bezel pics as requested...
11-21-2017, 11:57 PM | #122 |
Thanks!
11-22-2017, 04:22 AM | #123 |
Looking great
Posted via Mobile Device |
11-22-2017, 07:17 AM | #124 |
Nice work!
11-22-2017, 10:07 AM | #125 |
Awesome work. That black bed looks nice!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
