09-04-2015, 01:30 AM | #26 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Hooker 68-72 big block Chevelle headers fit my 69 C10
I have a 4" - 4" drop with a big block on factory small block springs. The collector flanges are 2-1/2" off the street. I'll post some pics tomorrow...If you plan on using your truck for a daily driver, these long tubes wont last. I have metal inserts in my springs up front as well as a half coil cut off the bottoms. Its stiffer than the 2" drop springs. I did that to clear the 30" BFG 60's I had at that time. I have 5" wide, 28" Mickey T's on it now and added the big block that squatted the front even more. But this truck see's an occasional drag strip, street races and shows and not alot of miles of uncharted street. 4" drop is the borderline for long tube headers in my opinion.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-04-2015, 07:05 PM | #27 |
I actually have 4-1/2" inches of clearance... Have a happy and safe weekend everybody! Off to "Greaserama!"
10-17-2015, 01:46 PM | #28 | |
10-17-2015, 01:48 PM | #29 |
Does anyone know if big block headers from 73 up fit in a 67-72
Posted via Mobile Device |
10-18-2015, 08:29 AM | #30 |
motor exploder
No, I'm running a tremec 5 spd with a hydraulic clutch.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-18-2015, 11:34 AM | #31 |
10-18-2015, 11:50 AM | #32 |
motor exploder
they're not...
10-25-2015, 07:59 PM | #33 |
I realize this is an old thread but curious if anyone has used a lokar cable or rod with a column shifted automatic? I like the idea of having more ground clearance with the chevelle headers but I'd also like to keep my shifter on the column. Anyone?? -Brian
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
10-25-2015, 08:57 PM | #35 |
10-25-2015, 09:06 PM | #36 | |
05-05-2016, 11:32 AM | #37 |
Bosshogg69 would your Hedman headers work with a stock trans brace? do the collectors come back the same distance, looking at the pic on the hedman web site the drivers side looks to be longer. I want to use chevelle headers if they will fit up with a custom exhaust and stock brace. this is what I have now. I have no idea what kind they are or what they are for but the length is great but the drivers side front tube is not right cause the PO had to cut WAY to much of the engine stand
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
05-07-2016, 12:51 AM | #38 |
These headers work with the OE trans crossmember and you dont have to cut anything. They also clear the auto-trans shift linkage as well... Best bang for the buck! Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big... ...If your dead set on "Chevelle headers" then I have a brand new set of ceramic painted long tubes that will clear the mounts for $200 shipped...PM me if you want them.~Ghostrider~
05-07-2016, 01:50 AM | #39 | |
05-08-2016, 12:49 AM | #40 |
Thats cool because the 110's are a long tube header that hang way down...Do you have a part number we can log for future use?
05-09-2016, 11:29 AM | #41 | |
Keith
06-10-2016, 04:15 PM | #42 | |
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. Last edited by AnotherWs6; 06-10-2016 at 04:25 PM. |
06-10-2016, 11:33 PM | #43 |
60-66 Nut
I don't know what the heck a front sway bar has to do with the fitment of headers ?????
06-11-2016, 01:05 AM | #44 |
Me neither Vernon, but there it is.
Will Not Fit Camper Special Or Vehicles Equipped With Front Sway Bar
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
06-11-2016, 03:11 AM | #45 |
My BBC 72 C-10 has the sway bar and like Captain indicated, not even close. They fit like a dream and my 396 is sitting in the front holes on 71 BB stands with small block mounts bolted to the motor...I've got pics somewhere, I'll post them up if I can find them.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 06-11-2016 at 03:16 AM. |
09-04-2016, 03:52 PM | #46 | |
09-04-2016, 03:56 PM | #47 |
04-01-2017, 09:32 PM | #48 |
06-15-2017, 11:32 PM | #49 | |
10-23-2017, 11:47 PM | #50 | |
