#301 | |
Re: 1970 Med Olive Project
#302 |
Your progress pics and clean work motivate me. Wow!
Keep the pics coming.
Rincon |
#303 |
![]() Join Date: Jan 2015
WOW!!! You are going to be driving that truck in no time! Everything you have done looks fantastic!!!
Jimmy Hoelzel |
#304 | |
![]() Join Date: Jun 2009
![]() https://www.summitracing.com/parts/wil-261-13271-bk
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#305 | |
I also must say that I am really enjoying watching you two (Mike and Larry) with your builds. I am in the process of doing a little bit of what both of you are doing. Kind of a blend of some of your best. I just hope I can execute the plan as well as you two have! Although I am not lowering my truck quite as much as you are Mike. Thanks for all of your posts; although my wife probably would not second that sentiment! David |
#306 |
![]() Join Date: Dec 2012
This is excellent advice! I would feel horrible if anyone followed what I did and ended up not happy with the results, especially with the components being as expensive as they are.
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#307 | |
![]() Also, based on your whole thread anyone can tell you know waht you talk about. |
#308 |
Absolutely not sir! I agree 100%
#309 |
#310 | |
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#311 |
Smittee is actually using the exact same front and eear brakes that I have. I agree wilwood should be the one I ask and will contact them but it seems the answer I will get is the same as you got. And yes Mike is smarter than the average bear.
#312 | ||
#313 | |
#314 |
It's enough to bug the **** out of me. Thank god the condensor is going to hide it or I might need therapy
#315 |
Haha, Im glad that Im not the only one highly annoyed over things like this. I figured the same as you, at least it will be covered.
#316 |
#317 |
Between my son's track meets and Easter Sunday I didn't get much shop time this weekend. I was able to slip out there a little Friday night and a little Saturday night and finished laying down the FatMat. I ordered 100 sq ft off of Amazon for $149.00. It came with two 50 sq ft rolls and I didn't quite use a whole roll. I do plan on removing the door panels and puting some behind there as well so I might get into the second roll. I hardly had any waste at all. One thing I will say is be sure where you want it because once it's down there isn't much chance in getting it back off
#318 |
Looks good Mike and should help reduce noise and heat.
#319 |
I am planning to buy my carpet from "Stock Interiors" . I am unsure of what color will match my interior so they are sending me some samples to compare against my seat and door panels before I order.
Here is a picture of my seat that I want to match and my SPID. The SPID shows the truck came with 629 Olive Custom cloth. Stock Interiors offers two dark green colors in the 80/20 loop, 509 Dark Olive green and 588 Dark Green. I will post pictures of the samples when they arrive. The carpet I want to order is for the high hump and no gas tank so the carpet extends all the way to the back of the cab. I also plan to get the mass backing for additional sound and heat control. My truck just has a black rubber floor mat in it right now. I am back and forth on keeping the rubber mat or going with carpet. I like the minimalist look of the interior with the mat but I really hate how loud and hot the truck is to drive. Throw some opinions at me guys! ![]() ![]()
#320 |
Are you trying to make the interior look more factory, or are you doing custom gauges and different things like that?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#321 |
nah, I'm not trying to make anything look factory correct but I also don't plan to change anything but the gauges. The gauges will be Dakota Digital VHX but everything else will remain as you see it in the picture. My only reason for considering the carpet is for comfort only.
#322 | |
The sound deadening, sound isolation (foam layer), & MLV barrier definitely makes a difference. My dually has 1 3/4 long tube headers, 3" SS exhaust tubing thru 3" Dynomax mufflers (under the back seat area of the cab), & then transitions to 2.5" SS tailpipes. With the windows up, it's quiet inside (quieter vs the stock manifolds/2.5" pipe & glasspacks that were under the bed).
#323 |
Scoti,
You may be in to something with the black carpet vs the dark green.
#324 |
I'm thinking about replacing my rubber floor mat with black carpet also, the rest of the interior is blue. The rubber is to difficult to keep clean looking and I hate when little rocks get under your foot.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
#325 |
I personally think black will fit the look of the truck the best
