04-11-2017, 01:39 PM | #1 |
Weatherstrip glue
What have you used to hold your door w/strips on? I've used weatherstrip adhesive with not so good results so now thinking of gorilla glue. Im stripping 20 years worth of old stuff off and painting the area where they sit. What's the best stuff to use. Squeeze bottlr or brush on?
04-11-2017, 02:56 PM | #2 |
Re: Weatherstrip glue
http://s1299.photobucket.com/user/jb...23904108567829 |
04-11-2017, 03:09 PM | #3 |
Don't know about the year of the truck you are referring to, but on the truck I've got it had the plastic push in pins that are used in the door holes. Aside from this, 3M sells a weatherstrip adhesive that I have used that is real good. take a good cleaner to the area, put your weatherstrip material on it, tape over to help hold and the next day it will NOT come off.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
04-11-2017, 03:12 PM | #4 |
Do yourself a favor and follow the link he posted above. The "Push on" style seem to be a much better option. I just pulled a " glue on " that wasn't glued anymore and put on the push type. Huge improvement for sure.
There is a thread on here somewhere and I believe you can buy a Honda door seal that will work as well.
1964 C-10 short bed 406 small block 700R4, 4:11 gears 20" wheels |
04-11-2017, 05:03 PM | #5 |
I think a glue that would work well would be the (3M?) stuff they sell at appliance places to hold on dryer drum seals.
When I got some Honda seals at the junkyard I put the almost new sponge rubber stuff aside to my collection of spare parts. I'll be going through that again and tossing it in the garbage. |
04-11-2017, 05:08 PM | #6 |
04-12-2017, 01:28 PM | #7 | |
04-12-2017, 01:57 PM | #8 | |
