#476 |
Re: What did you do to your Blazer/Jimmy today?
Bought a jimmy to go along with my blazer. The orange blazer is mine the white one was my cousins but he sold it recently.
71 Cheyenne 72 k5 71 jimmy 72 k10 |
#477 |
AWesome jimmy. Looks to be in great shape.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
#478 |
So this happened today...
#479 |
Very nice, what size are the wheels?
#480 |
#481 |
Finished blasting and shot a coat of primer on the floor.... Was in the zone and didn't think to snap a shot in bare metal... Also received a set of 4" skyjacker lift springs to eliminate the lift blocks.
#482 |
I wash it and polised it
#483 |
![]() Join Date: Jun 2002
Trimmed and fit a windshield frame. Hopefully get it welded in tomorrow. I had been dreading this, but it wasn't as bad as I thought it would be.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#484 |
![]() Join Date: Jan 2007
Wow -good work RG! Coming together nicely.
#485 |
Thanks, I have a long way to go... hows your's going?
The bad news is I didn't have time to weld it in today, the good news is I was able to use the shorter frame I had so I still have another windshield frame I can sell to help someone else get theirs done! Silver linings all around. Rg
#486 |
#487 |
Sofa King Crazy!!
Fabbed a bracket to hold my airride stuff and had it powdercoated. Didn't do it in one day but got it installed!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#488 |
Finished painting the dash and tomorrow I will spray the frame.
#489 |
Probably the old sony camera I use! I think it flashed on the last pic but not the first (later in the day) It is green, not tan.
#490 |
Nice work on this, Rg
#491 |
#492 | |
Do you have a build thread for this Blazer? Good luck, Rg
#493 |
#494 |
Removed my transfer case to get it rebuilt for my 6.0 LS / 4L60 swap.
![]() 1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
#495 |
Got a little more painting done.
#496 |
Blasted and primed the frame... Trying to choose what to top coat it with. I might try some thinned down bed liner sprayed on with an hvlp gun with 2.0 tip for the top coat.
#497 |
I got tired of the Blazer Hedman's scraping the ground, ended up with exhaust leak so I got some Chevelle Hedman headers. They're thicker and pretty nice looking. Didn't use the gaskets that came with though. Also swapped out both cross members with cut-out cross members from CPP. Plenty of clearance now.
TM |
#498 |
Not super exciting but I added a light to my center console
#499 |
![]() Join Date: Nov 2013
There was an old 70s era roll bar in the parts Blazer I bought....in the process of modifying it for a better fit.....
need to finish welding it....sandblast..... and go to powder coat. I bought a nice new set of 3 point retractable seat belts from MCB Matt one of our vendors... gonna mount the top link to the roll bar...... rear supports were too short to fit on top of the wheel hubs added 9" to them view from the back..the pic makes it look taller than the windshield.... it's actually shorter final fitting before welding the supports in
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#500 | |
