10-16-2016, 01:39 PM | #226 |
Re: Hemi's 70 Blazer build
Went for a nice fall colors tour this weekend. Probably the last big drive of the year before the Blazer gets put away for the long winter hibernation. Put almost 300 miles on this drive and used just under a half a tank of fuel. I sure love that 5.3 !!
01-15-2017, 03:03 PM | #227 |
Hey Dan, I think I read somewhere in another thread that you had said on this build that you didn't close up any of the original holes in the firewall. I believe you said even though you weren't using them that you wanted it to remain original. I am doing the same. My question is what did you do with the square hole that the original bulkhead of the wiring harness ran through? Did you use it or did you find a grommet of some kind? I wish to use the square hole but for a solid round cable of wires.
BR549 |
01-15-2017, 09:28 PM | #228 |
Amazing build! I hope my blazer looks close to this one day.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
04-10-2017, 02:40 PM | #229 |
Just brought the Blazer out for the first time this year. I decided to tackle a rattle that has been bugging me since I finished the build, and finally got it solved. I put a small rubber block on the door window frame that contacts the A pillar. Man, this made a huge difference, because it now prevents the two from touching on rough roads. At least now there's some pressure on the door when closed. Best part is that it's almost impossible to see when the door is closed.
04-10-2017, 04:35 PM | #230 |
I'm trying....
Another solid Blazer hack. Very smart Dan.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
04-10-2017, 04:40 PM | #231 |
What a great idea!
04-13-2017, 03:57 PM | #232 |
awesome idea i need to do that on mine
04-14-2017, 01:06 PM | #233 |
How did you attach it to the window frame? Sheet metal screw?
Thanks, great thread! |
04-16-2017, 04:17 PM | #234 |
Yeah, I didn't want to put holes it it but figured it wouldn't move if it was screwed down.
04-16-2017, 04:18 PM | #235 |
04-17-2017, 03:05 PM | #236 |
New Member
I just went thru your entire build, very nice job and cool video.
I noticed on page 1 that you made your own rocker reinforcement plates from the old rusty ones. I'm currently at that stage with my 70 Blazer and was wondering if you have a .dxf file for the profiles you would be willing to share? Thanks Mike |
04-17-2017, 03:32 PM | #237 | |
PM me an e-mail address that I could send it to. Dan |
04-17-2017, 03:55 PM | #238 |
New Member
PM Sent
04-17-2017, 04:24 PM | #239 |
OK, file sent !!
Let me know how it works. Dan |
06-28-2017, 03:50 PM | #240 |
Finally got a day with no rain !! Went to the lake to see how high the water levels were because we are at record conditions. Looking forward to another trip to the Syracuse Nationals in a couple weeks. Hoping for better weather.
