63-66 V8 fan shroud
I recently stumbled onto a '65 or '66 Suburban while scrounging for parts.
It is a factory V8 truck. It still has the original plastic radiator fan shroud, and it is in great shape. I was thinking about trying to work the shroud into the deal with the other parts. I don't recall ever seeing one. How rare is it? |
![]() Join Date: May 2007
Re: 63-66 V8 fan shroud
They make repro fan shroud for 64-66 chevy trucks. The originals are usually crack, split or broken.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
what does the fan shroud do i dont have one in my 65
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
One foot in front of the other
![]() Join Date: Aug 2008
The OEM ones usually got thrown away when the radiator or water pump got changed. The shroud helps with the efficiency of cooling of the engine.
Did the OEM shroud fasten to the radiator or to the support?
Is the shroud adaptable to aftermarket radiators? I have an OEM shroud from a '63 Impala I was gonna try to use on mine. |
It attached to the sheetmetal extensions on the either side of the radiator. I have repoped shroud for a 64 on mine. With a 21" fan, I had to do a little trimming but it does work well.
Is your '63 Impala shroud the one that looks like metal corrugated pipe section?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
OEM V8 radiator shrouds attached to two panels that bolted to the core support.
The fan shroud helps in the summer months if you get stuck in traffic or maybe a parade.
Aside from helping the fan out at low speed, it does provide a certain element of protection too. You know...from stuff like falling beers or getting the drawstring to one's hoodie wrapped up in the moving blades while bending over the radiator. (Ouch, that'll leave a mark)
#10 | |
#11 | |
