#76 |
Re: What did you do to your truck today part IV
I have this on the to do list after this years cruise'n season is over. Did you order a kit, or go DIY? And if you went with a kit who did you order from and why did you make that choice. I know there are a few options available here and I'm not sure who I want to order from yet.
#77 | |
That said, I had to do a little engineering of my own, as this kit was designed with a shortbed Chevy in mind, and I'm going a longbed GMC. Depending on your application this could be pretty straight forward, or a little more involved, especially with measuring. I had some issues with quality that I got resolved, and I think were a one-off. My biggest complaint is that while the product seems to be of good quality, the instructions are below standard. They're essentially copies of hand drawings, with handwriting. The first page with some measurement and step info is typed, but any illustrations are back-of-napkin quality. While not altogether a bad thing, when you compare it to something like RideTech's work you can see the difference. That said, Ridetech stuff is also more expensive, so you pay for the extra work ![]() I would do the No Limit kit again, primarily because I have now done it and know what I'm in for. But ask me again when I'm all done haha. |
#78 |
![]() Join Date: Mar 2013
Painted the new air filter up.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#79 |
That is a great looking engine TJ! Mine is still pretty crusty. But did get a new red top optima and battery ends today. Got tired of wiggling the wore out old connector lol.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
#80 |
Filled it up with gas then went and drove it until half of the gas was gone.
#81 |
![]() Join Date: Aug 2011
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#82 |
I didn't do it myself, I had it done. It's been warming up out here so I had the windows tinted the other day, kind of on a whim. To be honest, I'm not 100% sure if I like the look on the old beast but it certainly keeps the cab cooler.
#83 |
Headlight relay upgrade along with new headlight and dimmer switches.
Dimmer switch bolt had a clutch head so I had to make a bit. Headlight switch gave me back my dash lights, love the red bow tie high beam indicator. She was thirsty so I took her to fill up
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 Last edited by Northwest Outlaw; 04-23-2017 at 04:35 PM. |
#84 | |
Chris
#85 |
Friday i got my ram horns.Then i took them to get ceramic coated.
#86 |
I got new rims but the studs was to short.Installed the new studs panted the drums.
#87 |
Finished up on friday any installed the rear sway bar.
#88 |
Saturday and sunday i tore the front suspension off. Then took a break waiting for parts. Then i worked on the 1961 impala frame off resto.
#89 |
#90 |
#91 |
They seem brighter in my garage, but i didn't really get a chance to drive much with the old set up to get a good comparison.
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
#92 |
Painted the Chevrolet logo in the tail gate and front bumper with one shot paint.
See before and after pictures.
1963 Chevrolet C-10 |
#93 |
I installed a Grunion air ride and front disc conversion also painted the frame with POR-15 and added a train horn since I already had the compressor and air tank for the airbags.
It dropped the body about 7 to 8 inches. It's not sitting on the floor but it makes a drastic difference in the look of the truck, for a fraction of the price and work. I am very happy with it. I also had to relocate the mufflers and changed the exhaust tips. SS-7 airbags Gauges and paddles for each bag Compressor 2-1/2 gallon tank All necessary hoses, fittings, and hardware Front and rear Mcgaughy shocks Mcgaughy drop spindles Mcgaughy panhard bar Mcgaughy C notch Mcgaughy 12" Front Disc Brake Kit; 6x5.5 Bolt Pattern with calipers See before and after pictures how she sits
#94 |
Wow much better. I thought those wheels look a little out of place with that much altitude.
#95 |
I got my truck back from having the 700 r4 installed. I think my drive shaft is hitting my e-brake brackets when I go over bumps so I might have to do some rearranging. Have not got a chance to drive it on the freeway at a reasonable speed to see how it functions. To much traffic
#96 |
Painted my dash cluster and improved illumination. I used white paint for the back of the aluminium bezel and inside the cluster housing and red on the front of the bezel. The speedo face was a pain to mask off since the needle didn't pop off for me. My wife was really impressed with my skills until i told her the lettering was all still the original! I added a reflector inside around the speedo so the light bounces to the front better. One of these days i'll get the LED replacement bulbs for the lights The PO has butchered the cluster before i got it so i'm not ruining an original
#97 |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#98 |
Temporarily install my trim molding to mark out where I had to paint, the applied a few coats of white and about 7 coats of clear.
#99 |
Today i got my ram horns back form ceramic coating. I am installing them today.
#100 |
