1972 Blazer 4x4 to 2WD Conversion
I am in the process of converting a 1972 Blazer 4x4 to a 2wd. My question I have is related to the rear suspension regarding the shock cross member. Does anyone sell this cross member along with the trailing arm cross member. As far as I know, the c10 pickup shock cross member made by CPP will not work on a 1972 blazer frame, also I do not think the trailing arm cross member from a c10 will fit the blazer frame either....Any direction or advice would be great. Thanks.
Active Member
![]() Join Date: Sep 2013
Re: 1972 Blazer 4x4 to 2WD Conversion
Wasted Income did a 2wd conversion using Porterbuilt stuff. Project Family Truckster is his build thread. If you don't have the money to go that route try a axle flip kit by Belltech, it's a six inch drop. I was use going that on my 74 k5 but decided to stay 4wd.
1972 GMC C2500 Tow Rig project 1972 C10 Air Bag project 1967 C10 Drag Truck project 1967 GMC Patina Special project 1968 C10 I have no clue what to do with project 1969 GMC C6500 I wish I had more money project 1986 K10 I have too many damn projects |
Starting the process....4x4 to 2wd conversion on my 1972 blazer.
Removing the leaf springs and clean up the frame. |
Any updates? I bought a 70 k5 4x4 and I'm about to start a 2wd conversion. I bought a 2wd front frame section and transmission cross member. I know I will need to drill new holes for the front cross member and plan on doing a flip kit for the rear end. Did you run into any snags?
Keep us posted. This thread seems like it would offer a lot of useful information.
Update: Installing the front cross member from a 1973 chevy pickup and found trailing arms / rear diff to add to this project. Addition of a 496 Big Block and a 700R4. I am done rebuilding the transmission, block is at the machine shop.
I know every one seems to be alarmed with a 700R4 behind a big block, I build transmissions for a living so I guess its not a big deal to me plus I do not beat on my trucks to break them....drive them to enjoy not to destroy !!!! Bought the Porterbuilt trailing arm tubular cross member. not in pic.... Going to Fab in rear spring frame supports, pics will be coming soon........ |
72 2wd k5 blazer 86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE |
A guy with a truck
I did a trailing arm conversion a few years back (maybe 10). If I was doing it now, I would definitely use the Deadend Garage pieces
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#9 | |
The latest look of the 72 blazer 4x4 to 2WD conversion. The tires in the rear align with the tub. Test fitting everything, next will be attaching the fenders. Than take it all apart once more. Having fun !!!!
I know it’s an old thread but maybe someone can answer this...if you do a blazer with the trailing arm suspension doesn’t the crossmember sit really really close to the rear tail of the trans? Looking to convert a pickup to a blazer roadster and if I shorten my frame another 8 inches there won’t be a huge amount of room in that space. I don’t have my LS engine up against the firewall, either. Looks like I might only be ok because I have the CPP crossmember and the driveshaft hoop is taller than the stock crossmember. Maybe it’s because the old th350 trans is shorter than my 4L80E?
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#12 | |
A guy with a truck
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by Liz; 01-14-2021 at 02:29 PM. Reason: edited by staff |
