Old 04-24-2017, 11:32 PM   #651
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Br3w City's Project omgwtfbbq
By popular request, the GrillCraft tag was pullled off. Gotta agree, it does look better.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-24-2017, 11:41 PM   #652
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Before I get to the meat of this post, I wanna first give a quick thanks to Ryan Duke here on the forum. He contacted me about his LS swap, and ended up coming through in the clutch on a part of my rebuild. I've got video of his swap coming soon to my channel, but in the meantime check out some of his posts on his truck!
He knew of a local junkyard spot that just so happen to have a 4/5/6 out on the back 40. Turns out there was a 4/5/6 fleet small window, as well as a 'burb and a few other vintage scrap piles (video of that coming to the channel TOO, you should be sub'd by now...). Not much was good on the 4/5/6, except the chunk of back panel that I would need to do a patch job on mine...and good rear glass to boot. We cut the whole back off (it WAS NOT worth saving any other part, it was swiss cheese) and I took it home for $40.
My rear cabwall on the passenger side is pretty knackered if you hadn't seen it, here's a flat edge against it.
After much debate on the pull vs patch decision, getting this cab wall pushed us to the patch option. The old panels are just too creased to pull, so we started planning cuts to relieve stress on the metal. This let us return the nearby areas to a more neutral position. We removed a strategic section of the wall (YES there will be challenges, but we have a plan for most of them).
Old 04-28-2017, 02:52 PM   #653
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Paid a visit to another local member to help get his swap up n going. Take an introductory look at Ryan's build!
Old 05-03-2017, 10:44 PM   #654
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Another update.
Used a jack and some wood to prop the fuel cell in a rough area where I wanted it. I could move it around as needed while I took measurements. After that, I started laying out some 1/2" square tube for the skeleton.
I tac'd those into place and used the jack again to align the whole thing. I made some tabs for mounting, since I wanted the assembly to be removable and potentially allow for a different cell (alternate fuel possibly?) to be put in on 4 bolts. I also wanted my cell to sit as a certain height, and to naturally counter the rake of the truck.
I gusset the back side with the longer arms, and the whole thing could be set back into place. Then I drilled and tapped the tabs into the frame. The assembly has 4 bolts threaded right into the frame on 3/8-24 fine thread grade 8 hardware.
I also reused my old top strap with a few different bends in it. It hooks to the longitudinal strut I added (where the battery tray will start ...in the next paragrash ) and uses another 3/8 bolt, locking the fuel cell in place should gravity fail, or should I be upside down.
And after a bunch of grinding and some blending, I hit it with a few coats of prime and satin black.
At the same time as all this ^^^^, I was working on the battery tray also. Its a triangular skeleton with a flat stock floor plate welded into it for the hard mounting on the battery box.
I think its strong enough for me, so the battery should be ok.
I had to make a few small trims to the battery box plastic shell, mod the hardware, and narrow the battery hold down (was designed for larger battery than I run). The box and bracket dropped right in and sat firmly and squarely (triangularly? lol) on the base.
Old 05-08-2017, 07:25 PM   #655
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Awwww yeaa. Ryan located a cab for me, so we went to hack the good part off
Old 05-09-2017, 11:42 AM   #656
Ryan Duke
Whos that awesome Ryan guy in the vids? I like the progress, sometimes we all need alittle push from a complete stranger to get you jump started! It's all looking very good tho. If your ever in need of some help just let me know.
Ryan Duke is offline   Reply With Quote
Old 05-09-2017, 07:47 PM   #657
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Truck community for the win. Your help has been huge so far man, only hope that Dan, myself (and any of the other guys I keep around) can offer the same help getting your stuff on the road too.
btw I have your radio keys to return. They didn't fit the deck
Old 05-19-2017, 06:16 PM   #658
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Finally got the video part done for the initial frame rebuild!
Old 05-29-2017, 02:02 PM   #659
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Happy Memorial Day. Learn a damn Trade for America.
Old 06-01-2017, 10:02 PM   #660
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well, it was about time I put up some pics of the work on the cab wall. We sectioned the donor cab out and made a patch. Tons of hammering, dollying, planishing, welding, etc.
The old stuff hitting the scrap trailer.
Coming back to stitch together the seam.
Old 06-04-2017, 10:11 PM   #661
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Got the bumpers put into the fuel cell holder and could put the cell back into it.
Since there has been SO much work done on the frame, it was about time to clear everything off and give it a once over with the wire wheel to clean all the little areas.
Old 06-05-2017, 06:19 PM   #662
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Finishing up the rear frame section!
Old 06-08-2017, 10:38 PM   #663
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Pics and extra looks at the frame from the video (PLEASE checkout the vids too!)
Old 06-11-2017, 08:53 PM   #664
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
LOL yall got on me for a lack of updates...I hit ya with mad updates....no love
Another NEW video drops tomorrow, on the bodywork updates! In preparation, here's the pic dump. Progressive work on the filler building, leveling, sanding, and glazing.
On a related note, these things work really well.
SO, the new video on the process will drop tomorrow over on the channel. The progressive sanding is wrapping up, she'll be ready for prime and color this week.
Old 06-12-2017, 11:15 AM   #665
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yay moving pictures
Old 06-19-2017, 11:22 PM   #666
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yes, MORE new videos. Building the fuel cell frame, and a BONUS video on a pretty awesome tool I tried for the first time during the rebuild progress. Are you guys still out there? Its been so quiet
Old 06-23-2017, 09:17 AM   #667
SCOTI
SCOTI's Avatar
Yes, we're still following your updates.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-24-2017, 12:16 AM   #668
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My social anxiety has temporarily quieted.
Old 06-26-2017, 08:08 PM   #669
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Trying to keep it coming.
Old 06-27-2017, 11:33 AM   #670
forestb
forestb's Avatar
Why are you not using washers? Love your truck buy the way.
forestb is offline   Reply With Quote
Old 06-28-2017, 12:07 AM   #671
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've got a video on these coming, but I wanted to share the install pics on the new headlights. These things are wild, and extremely bright, solid state LED's.
Pulled the old lights out. Due to the size of the big old heat sync on the LED's, I needed to clearance the mounting rings and base (I guess thats what its called?) Used the body saw to trim them up and then painted the thing to keep it clean.
These are standard lights, so they don't have a normal automotive connection. I had to clip off the push connectors and wire on some spades. Then I could clean the wiring up and get it tucked and routed into the grill.
Then I could put everything back in with the trim rings. They still need to be aimed, but damnnnn they look good.
Old 06-28-2017, 07:25 AM   #672
SCOTI
SCOTI's Avatar
It's your ride but I'll go public w/this..... That headlight mod? Not for me. I don't care how bright they might be, they just don't look 'right' on an old truck (regardless of any marginal increase in output).
Just one guys opinion so no worries.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-01-2017, 01:39 AM   #673
Grizz1963
Grizz1963's Avatar
Aaaarrrgghhhh....!!
Photophukit is really frustrating me on the updates I like to follow.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-05-2017, 12:21 PM   #674
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Grizz1963 View Post
Aaaarrrgghhhh....!!
They have hijacked ALL of their content and want nearly $300 a year to get it back. Im hugely dissapointed...since it guarantee's the end of photobucket (people just won't pay that for simple hosting). I'm working on moving my content elsewhere, but it might be a while. Its really a shame.
Old 07-06-2017, 12:05 PM   #675
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Even though Photobucket are garbage humans, there is still NEW stuff over on my YouTube channel! More updates on the truck, finishing up some loose ends, fuel system and more.
