Old 06-08-2017, 02:21 PM   #1
Capo_Customs
pancaked crossmember problem
I have recently put pockets in my lower control arms with bags, im running d2600 bags and my frame was 3 inches off the ground. So i decided to pancake my crossmember 1.5 inches to get a little lower. Well i bolted it all back together and it only dropped 1/2 inch. I know the control arms will hit before the frame but my mind is boggled as they are still an inch off the ground. Am i missing something? Im guessing with the motor and everthing in it it will drop some more. Any help is appreciated. Thanks
Capo_Customs is offline   Reply With Quote
Old 06-08-2017, 02:58 PM   #2
robnolimit
robnolimit's Avatar
Re: pancaked crossmember problem
pictures would help
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-08-2017, 03:25 PM   #3
morepower71
Did you clearance for the steering? Maybe that is what is holding you up.
Pics would help a ton.
morepower71 is offline   Reply With Quote
Old 06-08-2017, 03:33 PM   #4
Capo_Customs
I notched the frame for steering
Old 06-08-2017, 03:34 PM   #5
Capo_Customs
not sure why my pics are sideways
Old 06-08-2017, 07:27 PM   #6
Sik66
As far As my thoughts about this......Pan caking a crossmember won't change a thing to suspension height.....just drops front body height....
Sik66 is offline   Reply With Quote
Old 06-08-2017, 10:49 PM   #7
Capo_Customs
how do you figure? It moves the entire front suspension 1.5 inches.
Old 06-08-2017, 10:53 PM   #8
morepower71
Looking online those bags are about 2.8 fully compressed. What do yours measure?
Old 06-08-2017, 10:58 PM   #9
Capo_Customs
Ill check tomorrow. Its at our shop. But i think its more than 2.8 inches
Old 06-09-2017, 07:10 AM   #10
PGSigns
PGSigns's Avatar
I agree with Sik66. Pancaking changes just the frame height and not the crossmember. It does move the front up 1.5" in relation to the frame. I does not change any of the geometry of the front suspension to allow it to go lower.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-09-2017, 01:11 PM   #11
tinydb84
tinydb84's Avatar
Are you upper ball joints binding? Many people have to pie cut the uppers to decrease the ball joint angle.
Loosen you upper ball joint and see if it gets lower.
David
Instagram: myfabguy
Old 06-09-2017, 02:30 PM   #12
Capo_Customs
Ill try that. Thanks
Old 06-14-2017, 01:27 AM   #13
Sik66
How you go?.....get it sorted?
