Old 06-08-2017, 01:50 PM   #1
Nanook
Nanook's Avatar
Manual to Auotmatic
Just curious if anyone has attempted to swap out stock 4 speed for an automatic in a stock 64 - 66 K10.
I would like to keep the truck as original as possible and still utilize the rest of the stock drive train including the T-221. My plan was to include a stock automatic column and try to make it look like it came from the factory with the auto.
The truck will be mostly used on road with little or no off roading. The engine is a 292 six.
I would appreciate any thoughts.
Nanook is offline   Reply With Quote
Old 06-09-2017, 12:29 AM   #2
kwmech
Re: Manual to Auotmatic
Doubt very much you will find a 221 ever bolted to an auto. You could set it all aside and go with a turbo 350 and a 205. This will be the easiest and least expensive way.
Old 06-09-2017, 09:55 AM   #3
Nanook
Nanook's Avatar
The 221 doesn't bolt directly to the transmission on these, it is connected by a short drive shaft. I was just curious if anyone had swapped in any type of automatic. Didn't want to swap out more than necessary. Thanks for the input. Anyone else?
Old 06-09-2017, 05:12 PM   #4
'63GENIII
'63GENIII's Avatar
You can run just about any trans / tcase combo that you want with the divorced rcase. I had a T400 2wd and 221 in my 63. An automatic column might be a pretty tall order though.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-10-2017, 05:53 AM   #5
andrewmp6
Ebay or could get a tilt aftermarket one and paint it to hide it.
Old 06-11-2017, 02:38 AM   #6
'63GENIII
'63GENIII's Avatar
Didn't even think of that.
Couldn't he use a 68 -72 collapsable auto column? Tilt would be real nice though.
Chris
'63 k15 long step
Old 06-11-2017, 05:53 AM   #7
andrewmp6
I have no idea if it will work or not i think so but not sure.
Old 06-14-2017, 03:07 AM   #8
andrewmp6
Thinking about that are all the mounting points the same for that year column?If so id say use it since most wouldn't know it didn't come with it but will look factory.
Old 06-15-2017, 03:19 AM   #9
'63GENIII
'63GENIII's Avatar
Pretty sure that mine is out of a '67 - '72 4 speed truck. Looks like it's always been there... well as long as Ive had it anyway.
Chris
'63 k15 long step
