06-22-2017, 01:47 PM | #11 |
Re: 1949 Chevy with S10 swap. Beginner build with ambition!
The best feeling today was buying my first lot of stainless and grade 8 bolts. They will attach all this sheet metal back on. Doing some alignment and fitment. This looks pretty spot on to me.
I did this by putting a 4x4 and 2x4 between the frame and cab mount cross bar, then a 4x4 between the rear of the frame and cross member. That way I could mock up both ride height and the front fender across the wheel well. A little jimmying got it all setup right. I'll also now know how high I need to make my cab mounts. Win, win! with flash to try more light
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 06-22-2017 at 01:53 PM. |
