Front fender side emblem questions.
1). Where does one find those nuts that hold the emblems on?
2). What are those nuts called? 3). Was there any cushion material between the emblems and the fender? Thanks! |
![]() Join Date: May 2010
Re: Front fender side emblem questions.
1) Find at most Corvette and other types of restoration parts places... also lots of hardware stores. For example:
http://www.parts123.com/corvettecent...050f&ukey=5625 https://www.mcmaster.com/#spring-speed-nuts/=18sb3ap 2) Commonly called emblem nuts, flanged push nuts, pal nuts, speed nuts, etc. 3) No cushion material used. |
Moderator
![]() Join Date: Jun 2017
LMC has them under 30-0812...
Emblem nuts, speed nuts... http://www.lmctruck.com/icatalog/cb/full.aspx?Page=114 No padding under emblem... ![]() ![]() ![]() |
Thanks guys!
One last question....fenders have to be off the truck to put the emblems on? |
![]() Join Date: Jun 2014
Assembling mine now. If you have the fenders off, do it then - if not, pull the inner fenders (wheel wells). If you have the outer fenders on, shimmed - gaps set, etc. you don't want to mess with those!
Randy |
![]() Join Date: Dec 2012
Inners pulled for sure - makes all the difference in the world..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Inner fenders are off.
I don't think I can put the "Custom 10" emblems on without removing the fenders. Ugh.....and they went on so easily! |
i too would recommend a corvette vendor to locate correct nuts
how ever I just purchased a set of custom C-10 front fender emblems for my 72 from Classic Parts, and those nuts came with the chrome. Very nice chrome bits too |
![]() Join Date: Feb 2002
I have found speed nuts on my old Chevy Trucks that the PO packed the cavity with caulk for a better hold. Have not copied it yet.
#10 | |
Getting these "emblem nuts" is one of the last things for me to do now......I am going to try and "inject" blue nail polish into the "Custom/10" emblem, picked it out to match the front grill emblem color. Need to get this done so I can get the truck back together! |
![]() Join Date: Dec 2013
Use barrel clips so you don't have to remove the fenders , You get the size that fits the emblem studs . the clips are installed into the hole in the fender from the outside and then the emblem studs are pushed into the clips ,It's easy , they are cheap and it works .
![]() https://www.summitracing.com/parts/s...SABEgKlVPD_BwE they are on ebay with an assorted pack cheap, napa, most auto part stores |
#12 | |
How do they come back off? Twist off? |
Where's my beer?
You might try your local Lowes. Mine has a surprising assortment of automotive fasteners.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
I was able to install my emblems without removing the fenders by taking out the bottom bolt and wedging a block of wood between the fender and cab at the bottom. It's a stretch to get the top nuts on, but it can be done.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#15 | |
![]() Last edited by Grumpy old man; 08-05-2017 at 08:59 AM. |
