![]() Join Date: Mar 2011
The old door weatherstrip issue
http://67-72chevytrucks.com/vboard/s...d.php?t=634310
If you are having door weatherstripping issues, if your new door seals wont let your doors close, Go to the above link and read that thread--its a short thread but it has more GOOD information on door seal problems than any other Ive seen. Be sure to look at the seal profile pics.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
Re: The old door weatherstrip issue
Just a little more info on door weatherstripping.
On my build I started with precision push on seals (but the were a style that was sold about 4 years ago). They Did no/Would not work. I found a very good used set of 94 dodge Dakota door seals, installed them with the idea of testing the used ones, if they worked Id buy a new set. Well after a good cleaning they looked as good as new--I decided to leave them in place. I also ordered another set of the "New style" push on precision seals which arrived today. The new chevy seals have a thinner more pliable bulb which compresses more fully and easier. If I ever have issues with the dodge seals Ill replace them with the new chevy seals. Just a final word---If you are having door seal issues, the dodge Dakota (regular cab) 87-97- ish ARE an inexpensive good fitting alternative.
