Old 06-26-2017, 06:49 PM   #126
OKGMC4
OKGMC4's Avatar
Re: Mr Green Jeans - the 69 (or not) chevy, er gmc, project
And I've been thinking about brakes. I realized that I like the corvette brakes in my 56 gmc more than my dads 96 impala ss brakes. They are both four wheel disc and the rotors are similar in size. I know the SS is 500 lbs heavier but the biggest difference is in the calipers. Iron delco calipers don't beat the aluminum dual piston vette calipers. THEN I realized the brakes on the 69 are closer to the SS than they are to my 56. (Not to mention the 69 will most likely also weigh more as well. The c10 axle alone is a monster next to a Dana 36 independent rear) SOOO... I pulled the trigger on what I hope will rectify that situation. D52 front calipers and a complete rear disc kit from Wilwood. The Jeep stuff I had on the rear looks really light duty compared to the new stuff. The jeep rotors aren't even ventilated and the pad surface is half as big as the new rear pads.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-27-2017, 08:38 AM   #127
mcbassin
Still Learning
mcbassin's Avatar
Awesome brakes! Congrats!
Old 06-30-2017, 02:50 PM   #128
knomadd
knomadd's Avatar
You should be happy with those brakes. I did the same setup on my 71 and I love them. They stop well and look good too!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-07-2017, 07:08 PM   #129
OKGMC4
OKGMC4's Avatar
I saw a pic of a No Limit high mount rear sway bar and had an idea. It looks a lot like the left over rear sway bar from my 56 gmc. (I installed the 96 vette rear end but not the bar.) Ordered some rod ends and aluminum adjusting rods from Speedway and a set of Prothane bushings. I'll have to build some brackets on the lower control arms but I'm 90 percent sure this will work. The bar is 24mm which is 15/16" and hopefully that will complement my 1.25 bar on the front.
Old 07-07-2017, 07:13 PM   #130
OKGMC4
OKGMC4's Avatar
Good to hear. I've never used Wilwood before and was hoping they are as good as all the magazine articles imply they are. Those are sometimes driven by the manufacturers advertising dollars. I remember the late 90's when the same magazines tried to convince me that a set of underdrive pullies would make my 305 firebird a race car. Lol
Old 07-08-2017, 08:30 AM   #131
OKGMC4
OKGMC4's Avatar
Woke up at 1am. Read a book for a bit. Then the voices started. "Go in the garage" they said. "You'll die without a donut right this second" they said. "Would a llama or an alpaca look better in a speedo?" Not sure about the last two but I DID get the sway bar install done. Turned out great IMO. Now I have to go spend the rest of the day tiling a tub and laying down a new bathroom floor. If I can stay awake long enough.
Old 07-16-2017, 04:58 PM   #132
OKGMC4
OKGMC4's Avatar
So yesterday was Spitfire day. Working on this off and on for over a year. All it took was a fresh engine, brakes, suspension, wiring, paint, weatherstripping, and unbent frame to get it going. But at least we know it's good to go now. The owner liked the color so much he copied me.
Old 07-16-2017, 05:11 PM   #133
OKGMC4
OKGMC4's Avatar
Today's work has been more... shocking. I read a couple chassis setup books that said shocks should be as far out as possible and mounted vertically. Better balance and more damping ability. Since I'm lowered 6 inches mine were leaning pretty far. I almost bought the no limit kit but realized it needed to mount in the same place as my bed floor brackets. So I built my own using a set of 4th gen f body rear shocks.
Old 07-27-2017, 04:12 PM   #134
OKGMC4
OKGMC4's Avatar
I'm going to install bear claw latches. Tired of slamming doors in the 56 and want the security of a double latch. Problem is that the stock door handles don't provide the right motion for unlatching. I also would like something modern to fit the theme. I'm going to try Mazda CX-9 door handles.
Old 07-28-2017, 04:00 PM   #135
OKGMC4
OKGMC4's Avatar
Had to move and enlarge the finger cup behind the handle. Finally found a use for these u bends.
Old 07-29-2017, 06:38 AM   #136
OKGMC4
OKGMC4's Avatar
Old 07-30-2017, 07:24 AM   #137
OKGMC4
OKGMC4's Avatar
Almost there. May have to create a bulge at the front as well.
Old 08-05-2017, 05:22 PM   #138
OKGMC4
OKGMC4's Avatar
Old
Old 08-05-2017, 05:24 PM   #139
OKGMC4
OKGMC4's Avatar
New. Door handle works. Took me like two hours to bend up a rod that would fit and also actually work. Ever have a little part like that makes you feel REALLY stupid? Yeah. That. Me. (Sigh.)
Old 08-05-2017, 06:39 PM   #140
t300
Love the handle metalwork, looks great! And can't wait to see how the shocks turn out, putting Bilsteins on (long ones) is definitely on my todo list.
t300 is offline   Reply With Quote
Old 08-07-2017, 08:02 AM   #141
OKGMC4
OKGMC4's Avatar
Old.
Old 08-07-2017, 08:05 AM   #142
OKGMC4
OKGMC4's Avatar
New. Ended up really close to where the weatherstrip is. I think I can scoot everything back about 3/8 " and get better clearance. Otherwise I can shut the door easily and the handle works fine.
Old 08-09-2017, 08:03 AM   #143
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!
Old 08-09-2017, 12:18 PM   #144
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice work. It's looking great.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-09-2017, 02:18 PM   #145
OKGMC4
OKGMC4's Avatar
Originally Posted by mcbassin View Post
Very nice progress!
Thanks guys!
Old 10-29-2017, 12:29 PM   #146
OKGMC4
OKGMC4's Avatar
Bought a radiator. I came very close to getting an Entropy but the Mishimoto is nearly $400 less and has a lifetime warranty. It may not be quite as good but I won't know till I get it running. Dug around in the parts store and came up with a set of hoses. The Gates 20931 lower hose is an S10 application and is no big deal. The upper is a combination of a 22526 and a 20801 with some trimming and a 1 1/4" hose splice. They are a bit more obscure as one is a northstar Caddy application and the other is for several older European import cars including Opal and Triumph. I think it looks better than the stock Silverado 5.3 hose. More out of the way and less clutter. I tried one, and I just couldn't quite bring myself to force the 1 1/4" end over the 1 1/2" radiator side. The hose just would not fit and it reminded me of when a healthy corn fed country girl squeezes into a pair of Wranglers two sizes too small to go square dancing on a Friday night. Anyhoo, the 20801 reduces the hose size properly and I could keep the tub of Vaseline stowed for future needs. I also have a 3 piece set of covers for the grille and radiator on order so I'll report on those when they arrive and get test fitted.
Old 11-03-2017, 06:02 AM   #147
OKGMC4
OKGMC4's Avatar
Covers look good. Got them from Mod Shop Inc (on his ebay store). Overall very impressed with the quality. Also ordered several parts to start building an air intake last night. Coming along...
Old 11-03-2017, 07:17 AM   #148
OKGMC4
OKGMC4's Avatar
It just occurred to me that my grill, core support, both fenders, both rockers, both bumpers, and tailgate are chinese reproduction parts. My hood, cab, doors, rear quarters, bed floor, and frame are GM originals. That's 9 import vs 8 American pieces. Does that mean I am officially building an import vehicle now?
Old 11-03-2017, 08:27 AM   #149
swamp rat
swamp rat's Avatar
You have been doing some amazing work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-03-2017, 10:48 PM   #150
IRQVET
IRQVET's Avatar
I was thinking the same. Its one thing for a professional mechanic/ fabricator to build something cool, but a regular guy DIY build is something to behold.
1998 Chevy Tahoe 2D
1949 Willys CJ2A
1967 C-20 Flatbed (Sold)
IRQVET is offline   Reply With Quote
