07-16-2017, 06:36 PM | #1 |
Swapped the 235 for a 292, need some tuning info
A 292 from a 67 c20 with 46k original miles was practically given to me so I've done the swap and the motor runs good. I just can't find what the idle rpm, dwell, etc. are to tune it up right.
07-16-2017, 09:44 PM | #2 |
Re: Swapped the 235 for a 292, need some tuning info
Dwell is the same as your 235, 32 degrees. Point gap is .019" new, .016" used. Timing set at 4 deg BTDC @ 600 rpm. Plug gap is .035".
HTH |
07-17-2017, 10:05 PM | #3 |
Perfect, thanks! I'm about ready to get this thing on the road.
07-18-2017, 11:45 AM | #4 |
Over at stovebolts there is a good tech article on converting a later model HEI to use in earlier sixes if you want to go that route.
https://www.stovebolt.com/techtips/HEI_mini.html
07-18-2017, 08:05 PM | #5 |
here is a tech article i wrote up 10 years ago on the H.A.M.B to put a 250 gm HEI in a 235 chevy for future reference, cheap and easy! https://www.jalopyjournal.com/forum/.../#post-2039642
07-18-2017, 08:06 PM | #6 |
any pictures of the engine,transmission mounts? sounds cool!
07-18-2017, 11:46 PM | #7 | |
08-08-2017, 10:22 PM | #8 |
Not the best of pictures, but I modified the original cross member that the bell housing sits on and then boxed in the frame. I bought a pair of sbc motor mounts made for my truck, but had to slightly modify them as well. Overall, it was not too hard for this rookie mechanic.
08-29-2017, 11:18 PM | #9 |
I always wanted to pump up a 292 and maybe turbo it for my truck. they are cool motors man.
08-29-2017, 11:52 PM | #10 |
Guys used to really hotrod the 292 and big GMC sixes (300+ cu. in.) I had a buddy with a '66 C10 with a solid running 29 and a 700R4 behind it. That truck ran great and pretty damn strong too.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-04-2019, 04:25 PM | #11 | |
Do you happen to have any pictures of how the crossmember was modified? I also noticed no fan but it looks like one would fit, are you running an electric up front of the radiator? Thanks |
03-04-2019, 10:34 PM | #12 |
Tom Lowe over on 12bolt.com has a nice site great parts usin some of em myself
03-04-2019, 10:38 PM | #13 |
The one on my 48 was done rather crudely when I got it in 1973 but basically they did some cutting and rewelding to get the V8 bellhousing mounts to sit down on it like they would on a 54 or later crossmember.
Gents a bit of reading shows he PULLED the 235 out and INSTALLED a 67 292. Neverdone50 if you want to go HEI there is nothing to modify you just find one out of a 77/88 292 and probably a 75 or later 250. I've got one for my 68 292 out in the shed somewhere where I stashed it after we did an engine swap for a guy in a late 60's pickup and he wanted to keep the points as it was a farm truck. Simply meaning at the time his workers could figure out points but might not be able to figure out an HEI.
03-05-2019, 09:07 AM | #14 |
Here are the pics of the crossmember modified. I just notched it and welded some new plates on top. It fits like a glove and bolts nicely on place. There wasnt enough room for the original fan so I went electric in front of the radiator.
03-05-2019, 11:03 PM | #15 |
Thanks for the pictures Neverdone. I have a crossmember from a 55 but I almost think it would be easier and faster to modify the current crossmember like you did than to remove the original one and replace it.
