08-06-2017, 06:48 PM | #1 |
Whats this switch
Can anyone tell me what this piece is thats circled in the photo? I have a hole on each side of my K5, not sure what goes there. I would have guessed its the dome light switch, but my 78 has them installed on the front door jamb
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd Last edited by ADub; 08-06-2017 at 07:16 PM. |
08-06-2017, 09:58 PM | #2 |
Re: Whats this switch
Seat belt release. They were like that through like '87 I think.
08-07-2017, 06:59 AM | #3 |
How do they function? Ive got shoulder belts on my truck, but its currently disassembled. I remember them working fine without the releases?
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd |
08-07-2017, 02:00 PM | #4 |
It may indicate your shoulder belts may not be performing properly. Otherwise, I think they lock up....but I'm not positive. Or won't suck in tension..don't remember.
My 89' has them, so I'd say they ran all they way to 91'.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
08-08-2017, 06:21 PM | #5 | |
They work when you open the door, the belt retracts. Button pushes a tab and spring tension releases, winding up the belt. Pretty simple. The lock is different from the release. A hanging weight, looks like a fishing weight, works on gravity to lock up. 9 times out of 10 its just dirt inside that stops them from working. Sometimes the clock spring is broken. I have pix of them all blown apart if you need. I have many a day into fixing Blazer/Jimmy belts. A little fun fact...the passenger belt can be swapped with drivers side. Just flop the reels from the retractors behind the plastic cover. Figured that out trying fix a frayed driver side. These are a life saving parts so don't fool with them unless you are 120% confident in your skills. |
08-09-2017, 08:20 AM | #6 | |
08-09-2017, 11:45 AM | #7 |
You say they worked before you took the truck apart, then they will work after, right?
Belts retracted when you unclipped it from the female end? Maybe somebody put earlier '76-'77 belts in it. Pull the belt all the way out to where you see the tag. Tell me the part number on that tag and I'll tell you what yr those belts are. 78-90/91 belts all had plunger and yes it needs to be there to work properly. |
08-09-2017, 11:50 AM | #8 |
Thanks for the help. I havent put the truck back together yet. Its been apart for a while. I just noticed that I had a hole in door jam and nothing to go back in the hole, so I started searching for parts. I will test it all out once I get it back together. Hopefully soon, but prob not!
08-09-2017, 12:18 PM | #9 |
Hope it helped! Owned/parted out over 40 Blazers over the yrs.
I had to think about for a second but they couldn't be 76-77 belts. They used a different set up for belts because of the floor pan in the rear. '78 was first yr for the new footwell rear floor & flip/fold rear seat. The belts moved completely to the b pillar where 76-77 had a mount on the floor behind the front seat. |
08-11-2017, 09:07 PM | #10 |
Does anyone sell these new?
08-22-2017, 09:17 AM | #11 |
78K & 79C Jimmys
I've seen those out of alignment and it will rub on side, make sure the pin is centered, over spray can make it rub, I'd clean them and you might find debris inside
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
