08-10-2017, 11:30 PM | #1 |
Not Your Average Overheat Question
'70 C10 396, TH400 3-spd trans, mild cam, 454 heads, timing 36 total
Overheats at low speeds or at stops. If I go straight to highway at 65 it is fine. If it overheats at low speeds and then I hit the highway, it won't cool down, stays in the red. With rad cap off, I see good flow in radiator. With engine warm, in gear at a stop is 700 rpm, but in park it goes to 1800-2000 rpm. Here's my question: With temp in the red, temps on both ends of lower AND upper rad hoses show 210-213 degrees. No 10-20 degree difference. Why? New: Mishimoto 3-core rad Mishimoto twin puller e-fans, 2600 CFM; 1x 1100 cfm pusher fan 2x gauges 2x temp sensors rad hoses 2x water pumps (clockwise looking from front bumper), FlowKooler trans cooler inside rad Edelbrock 750 carb, mixture screws turned 1 1/2 turns out Edelbrock RPM Airgap intake manifold HEI distributor Hooker headers Rear gear ratio 3.73 |
08-11-2017, 12:27 AM | #2 |
Who Changed This?
Re: Not Your Average Overheat Question
Does it puke coolant when it overheats, or do you just see a high temp on the gauge? Could be a bad transducer (sender) or temp gauge. Nice looking under the hood, BTW.
08-11-2017, 12:37 AM | #3 |
Couple things I'm concerned with, and/or need verification about. Engine rpm when warm is 700rpm in gear but 1800-2000rpm out of gear? I've never heard of carb issues causing overheating but something is off there.
The other is you say there's 2 water pumps? Obviously I see the block mounted one but there's another? |
08-11-2017, 12:52 AM | #4 |
If your top & bottom hoses are reading the same temp then the radiator is not getting rid of the heat (I know, that's obvious)
Possible causes: radiator too small not enough air flow (fan shroud(s) no thermostat (coolant is flowing too fast) or any combination of the above |
08-11-2017, 12:59 AM | #5 |
Just so I am clear. You have two fans pulling air through the radiator? And an additional fan pushing air? If so the first thing I would do is remove the pusher fan. My experience with pusher fans is they only work as a single unit covering a such of the radiator as possible. They are always a poor option to be used only if no other fan will configuration will work as the blades will deflect as much air as they push through.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-11-2017, 01:13 AM | #6 |
I have never had any luck what-so-ever with electric fans. Just about tried them all. Last go-around was with my tow truck. Gen6, 454, nothing fancy single 3'' exhaust with iron manifolds, HEI and a Q-jet. Dual electric top of the line fan assy, self contained shroud. Always tried to overheat when Idling. I put a stock fan shroud on with a 7 blade fan and a fan clutch. Never had a problem since.
And as stated before, if you have the same temp at both hoses the radiator is not doing its job |
08-11-2017, 01:45 AM | #7 |
A radiator can look all fine and dandy by opening the cap and looking inside. Color of the coolant can even look great yet when you drain it from the bottom is will be a nasty brown color.
How do I know this! Been there. Most all coolant flush products are not that good at removing stuck on corrosion inside the radiator. Look at the ingredients of Prestone Super Flush. Sodium Citrate. Everyone says Aluminum in Radiators are great products. With the old Copper and Brass Radiators you can use products like Sodium Hydroxide, Oxalic Acid to flush your system with no harm to the internals on the block. They must be neutralized. Back flush the entire system and pull your drain plugs on the engine block when you do. A lean setting on the carb will make the motor run hot also. I had this and a couple other issues like a cracked manifold, and other problems too. |
08-11-2017, 08:46 AM | #8 |
As toolboxchev just said, I would make the carb is not too lean. I once spent s lot of time working on my truck's cooing system and the whole problem ended up being that the carb was too lean.
Posted via Mobile Device |
08-11-2017, 08:51 AM | #9 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-11-2017, 11:51 AM | #10 |
Idle in park is way high... mine idles in gear (warmed up) at 600rpm, then at about 800rpm in park. Don't think this is a cause of your overheating issue, but definitely seems odd, as Overdriven mentioned above.
36 total timing seems a little high as well. Have you tried it back down at around 32? Finally, I agree with Kwmech... I've used electric fans and, while mine did work decently, that was with a big, non-stock radiator. On my Super I'm using a six-blade, stock-size fan with a clutch, and a proper shroud, zero issues. That is a nice looking engine bay.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
08-11-2017, 01:27 PM | #11 |
You mention the idle mixture screws being turned out 1.5 turns but how is the carb calibrated? Is it the "out of the box" tune or did you calibrate it with a jet/rod kit? Sounds like it's a lean carb problem.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-11-2017, 02:07 PM | #12 |
You guys have hit everything that could possibly be. Let's see what he finds.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-11-2017, 02:25 PM | #13 |
motor exploder
You may have 36* total timing, but what do you have your initial timing at? What about vacuum advance? Is it hooked up and where?
What year are the 454 heads? What head gasket? Some issues may be there if using a Mark IV block (series flow of the coolant to the heads, which 396 is) with later Gen V/VI heads (parallel flow of coolant to heads) without the proper gasket.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 08-11-2017 at 02:31 PM. |
08-11-2017, 03:47 PM | #14 |
It idles @ 1800-2000? Holy timing batman! That will run hot.
Thats a great looking engine bay. |
08-11-2017, 04:10 PM | #15 |
Old member
The timing and idle are way off. You need to set the carb air screws to as much vacuum as possible at idle with a nice smooth idle also around 650 -800 RPM's.
The base timing should be set with vacuum advance disconnected and plugged at both ends, the carb end should have your vacuum gauge hooked to it so you can set them to max. This will require some playing with the screws. Keep both screws to the same amount of turns. You will have to set the idle screw also as you do this to keep it the same.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-11-2017, 11:03 PM | #16 |
Also check the choke make sure it's coming off of high idle. 1800 - 2000 sounds about right for the high idle
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-12-2017, 08:03 AM | #17 | |
Old member
Also make sure you have the advance hooked to manifold vacuum which is done by placing your finger over the inlet and it should tug real good.
08-12-2017, 06:39 PM | #18 |
Really good replies, thanks to everyone.,
I only have one water pump, a FlowKooler. https://www.summitracing.com/parts/BRA-1671 I took the front 1100 CFM pusher fan off. Now only 1300 Mishimoto twin puller fans (2600 CFM total) on. Carb mix screws 1 1/2 turns out, it came new out of the box at 2 1/2 turns out. Edelbrock said that's about right. No vacuum leaks anywhere. It starts bleeding coolant from rad to overflow tank when super hot. 19lb rad cap. Electric choke working fine. So, my son-in-law came over and got me to stop wanting 800 RPM at idle just because it feels smoother. He said I've got to live with the slight rumble from that cam. Now it idles at about 1200 in park, and 550 in gear at a stop. Still too much of a drop and not sure why. Motor nearly overheats at a stop but much better than deep red on the gauge needle. I've ordered two of Derale's 2100 CFM 14" fans (4200 total) https://www.summitracing.com/parts/DER-18214 with their 16795 PWM Fan Controller https://www.summitracing.com/parts/der-16795 They should fit my Mishimoto fan shroud perfectly and give me a tight seal. I'll let you know if it fixes the overheat. I don't like it when guys ask for help, get lots of answers, but never tell you what actually worked. You, too? Ha! |
08-12-2017, 07:45 PM | #19 | |
To compensate at present you likely have the curb idle screwed in enough to let it idle like it does. Two problems arise from that. Retarded timing makes it run hot. Increased primary throttle opening has it idling on the power circuit. A test to check for too much throttle opening is to screw in either mixture screw and see if it quits. What's your timing curve like? How much initial? How much mechanical? |
08-12-2017, 07:53 PM | #20 |
Old member
2500 bare min on cfm fan for a big block! 2 fans @4200 means they both have to be on all the time. One fan is only 2100 CFM This isn't enough to keep the BB cool!
The turns on the carb are starting points not the rule. The idle in park you need to adjust them to the max vacuum period! No question about it. It's the only way to do it. 2 turns maybe right for your setup but until you do the adjustment trust me it needs to be checked. Check out their video on it. Cooling. Rule of thumb! 1,250 CFM for a 4-cylinder 2,000 CFM for a 6-cylinder 2,500 CFM for a 8-cylinder Note: Big horse power means big fans!
08-12-2017, 10:49 PM | #21 |
Thanks for last two replies today.
I just turned the mixture screws in all the way one at a time from 1 1/2 turns and it decreased RPM from 850 to 550 but did not stall engine. I can't check timing right now because when I installed a new water pump I also installed a new harmonic balancer and adjustable timing pointer. So I need to find TDC again to get the pointer right and will then check timing again. https://www.summitracing.com/parts/SUM-164700 (timing pointer) One thing of note is my vacuum advance is connected to port (passenger) vacuum on my Edelbrock 750 carb. Thanks again! |
08-12-2017, 11:37 PM | #22 |
That should be your ported vac port. Should be no vacuum at a normal idle (700 rpm).
Your high idle likely shows some vacuum. You'll need to use a piston stop to find true tdc #1 to set your pointer. Info here on that. http://www.crankshaftcoalition.com/w...op_dead_center You can make a piston stop from an old sparkplug or buy one. |
08-13-2017, 09:29 AM | #23 |
Old member
I just finished doing this to my 64 SS Impala. It has ran rough since I bought it but I lived with it like you until last weekend. I bought a new cap and rotor and installed. I found 1 bad wire and replaced it also. I then started messing with the carburetor and found the vacuum advance was hooked to the ported side passenger side of the carb so I swapped them. I then hooked the vacuum gauge up and fine tuned the 2 idle air screws to get max vacuum and it's running great now.
I do need to buy a new set of plug wires and plugs for it though but for now it's fine.
08-14-2017, 01:43 AM | #24 |
Hmmm, manifold vice port vacuum. I see alot of people talking about that online.
This week I'll put a t-fitting on my manifold line which I have a vacuum line running to my TH400 trans and cap off the port vacuum port on the carb and I'll let you know what happens. It would be really cool if that helps my idle issues and especially overheat issues at idle. Thanks! |
08-14-2017, 03:17 AM | #25 |
The vacuum advance line on the distributor needs to be hooked to a ported source. There are several reasons for this. It allows the advance to return to the same location everytime you let off of the throttle allowing the idle speed to be more consistent. As engine load affects vacuum and you don't want the that affecting your idle quality.
When the engine is at cruise speed on the road and you let up on the throttle manifold vacuum spikes high with a non ported source the ignition timing maxes out while the engine is experiencing a lean condition making conditions ripe for preignition detonation. With a ported source the timing is reduced when the throttle closes. This is why virtually every auto manufacturer during the carbureted era used a ported vacuum source.
