Old 04-25-2017, 10:40 PM   #926
mud.man.rj
mud.man.rj's Avatar
Re: 73-87 4x4s
Looks so nice even upside down.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 04-30-2017, 09:14 PM   #927
dfrank
dfrank's Avatar
Re: 73-87 4x4s
Mudman.
Thank you.
dfrank is offline   Reply With Quote
Old 07-16-2017, 10:41 AM   #928
Matt Man
Matt Man's Avatar
Re: 73-87 4x4s
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 07-16-2017, 01:42 PM   #929
JohnKimble
Re: 73-87 4x4s
Wow Matt, that is effing beautiful!
JohnKimble is offline   Reply With Quote
Old 07-25-2017, 11:30 PM   #930
'75K20
'75K20's Avatar
Re: 73-87 4x4s
Here's my truck to add to this post.
'75K20 is offline   Reply With Quote
Old 08-04-2017, 10:56 PM   #931
jocko
jocko's Avatar
Re: 73-87 4x4s
Wow, new photobucket policy pretty much destroyed this thread...
I should've posted this one a little while back (sold it recently) - 76 K20 Silverado Camper Special w/Special Paint. Miss it already!
Old 08-05-2017, 09:10 AM   #932
abig84
abig84's Avatar
Re: 73-87 4x4s
figure i can do one post and be done with it, list of all the square bodies ive owned.
my very first 4x4, 1983 s10 blazer. i think around 1998 2.8 4x4 manual transmission
few months later i got this truck - 1984 gmc jimmy 305ci 6 inch lift 38 inch tires
after about 4 years that thing literally fell apart so i found this suburban in a local impound yard for $200, it was stock when i got it. 400ci 6 inch lift 38 inch tires
same fate, few years later after offroading it the body became so tweeked i had to let it go and found a old military blazer for cheap so had that for a few years - 6 inch suspension, 2 inch body, 400ci engine
around 2010 i had the itch to get a pick up truck for some reason so got rid of the blazer and found a k30 really cheap and still have it to this day. the plan was to make it the new off road truck but when i was done building it, it was way to nice to destroy. 4inch lift 400ci 33 12.50 all terrain tires.
here was the only square body i owned that never seen offroad. it was a daily driver for a while til i sold it for something with a little better gas mileage (what was i thinking) 350ci 4 inch lift 33 12.50 tires
was in decent shape except for the holy rockers which you can see in the picture... also on the trailer was a 85 s10, cut the fenders off and stuck 35s on it. actually got about 3 years of fun out of that thing surprisingly
abig84 is offline   Reply With Quote
Old 08-11-2017, 05:15 PM   #933
Jsfucttruck
Re: 73-87 4x4s
I got a few.
First is my D/D. 87 V20 burb. I got it in stock condition a few yrs ago. It has a 6.2 diesel with no turbo and a th400. I have put a 4" lift( no blocks), warn bumper, 14 bff swap, and a whole lot of maintenance. It often takes my family on 1000 to 2500mile round trips to variuos 4x4 events. I average 18mpg in this pig. We often take backcountry roads that are off the beaten path. I love it.
Jsfucttruck is offline   Reply With Quote
Old 08-11-2017, 05:23 PM   #934
Jsfucttruck
Re: 73-87 4x4s
My wife's 91 V1500. This thing is fully loaded with options. It has a 8 lug 10bolt and a 14bff rear. 6" full spring lift and 35" Toyo's. We have been to Vegas, Death Valley, KOH, blah, blah. It is on it's 2nd 700r4 and about to get a th400 swap.
Old 08-11-2017, 05:45 PM   #935
Jsfucttruck
Re: 73-87 4x4s
Next is my family wheeler. It originally was a 78 K20 Burb. Factory 305/sm465/np205 truck with no options, not even a radio. It had 3.73 geared 10bolt/14bff. It is in the middle of a complete make over. It was bone stock truck. Skinny tires, sagging suspension, it was a perfect start.
Over the yrs it has had 3 motor swaps. I have gone from stock lift, to a 2" and a 4" . I had swapped in 4.10 ratio 60/14 but since then gone to a 4.56 set with lockers f/r, 35 spline outers, Yukon hubs, 1410 rear yoke, HAD driveshafts. I have crossover steering, twin stick 205, tubular cross-members, inboarded rear shocks, greaseable bushings, 4wh disc's.
It's been a long run road and I can't wait for the 3dr body swap to be complete so I can start the next phase. 3dr on 43"...
Old 08-11-2017, 05:57 PM   #936
Jsfucttruck
Re: 73-87 4x4s
The body pretty much rotted away. Floors, rockers, a/b pillars, rear pillars, and roof all had for from living on the coast. When I got it in 2010, it had none.
I collected 2donor trucks for the swap.
I am going to miss my square bodied burb, but the dream is coming true. Slowly.
Old 08-11-2017, 06:05 PM   #937
Jsfucttruck
Re: 73-87 4x4s
I am going to start tinkering on this soon. It needs a ton of work. It was a factory 454tbi/sm465/np205 truck. Hard to find these trucks. 87 K30. It has a carb 350 now. She needs window regs, clutch, brakes, tre's, wiring repairs, and a 4" -6" lift.
Old 08-11-2017, 06:11 PM   #938
Jsfucttruck
Re: 73-87 4x4s
My good friend has a few too. He has a 88v20 burb. Tbi350/sm465/np208 (factory equipt) with some over sized tires and a swing out tire carrier.
He also has a 89 GMC V2500 that we just swapped a hydro 465/208 into. No lift, just like his other one.
Old 08-12-2017, 12:02 PM   #939
USSkoval
Re: 73-87 4x4s
It's awesome seeing so many Burbs in a post!
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 05-15-2018, 12:58 PM   #940
leisure67
leisure67's Avatar
Re: 73-87 4x4s
My '80.
1970 K10
1970 C30
1973 C30
1980 K20
leisure67 is offline   Reply With Quote
Old 05-23-2018, 10:02 PM   #941
jocko
jocko's Avatar
Re: 73-87 4x4s
Originally Posted by leisure67 View Post
My '80.
Sharp truck! Got any more pics of it?
Old 05-24-2018, 06:37 AM   #942
leisure67
leisure67's Avatar
Re: 73-87 4x4s
Thanks. Ill try to get some.
1970 K10
1970 C30
1973 C30
1980 K20
Old 06-28-2018, 06:17 PM   #943
Matt Man
Matt Man's Avatar
Re: 73-87 4x4s
Just a updated pic of mine with 35's and toolbox.
Old 11-19-2018, 01:51 PM   #944
5661DWL
Re: 73-87 4x4s
Here is my '87 that I have owned for 26yrs. Did a repaint on it a few years ago. One engine rebuild and have had the trans and transfer case rebuilt once as well. When we did the repaint, I had the grill surround painted body color. I like the way it turned out. I had to retrieve the nephew's Subaru, first time using my new car trailer.
5661DWL is offline   Reply With Quote
Old 04-18-2019, 05:16 PM   #945
Steviebinmiss
Steviebinmiss's Avatar
Re: 73-87 4x4s
My 83 gmc "ol blue". Needs a lot of work, but I love it.
'83 gmc high sierra swb 4x4
Steviebinmiss is offline   Reply With Quote
Old 05-27-2019, 09:00 PM   #946
calvin78612
calvin78612's Avatar
Re: 73-87 4x4s
My 77 K20
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 02-12-2020, 12:46 PM   #947
ddc456
Active Member
Re: 73-87 4x4s
Here is a couple of my 79 3/4 4x4 (love the 73-75 grills, had to change it). Ol' girl even has factory bucket seats!
ddc456 is offline   Reply With Quote
Old 03-16-2020, 12:02 PM   #948
Greenlee
Greenlee's Avatar
Re: 73-87 4x4s
Here’s mine with her new shoes. 33x10.50 BFG all terrains. Stock wheels and suspension.
Greenlee is offline   Reply With Quote
Old 03-18-2020, 02:21 PM   #949
FoxCustom
FoxCustom's Avatar
Re: 73-87 4x4s
That is a beaut!!!! Sits nice and stout too. The yellow looks great.
FoxCustom is offline   Reply With Quote
Old 04-11-2020, 09:47 PM   #950
52napco
Re: 73-87 4x4s
This is my late father's last truck.1987 V10 Silverado. He gave it to my son before he passed and we had to have a lift..Looked for several years for the Warn combo kit and I had the M12000 winch.
52napco is offline   Reply With Quote
