Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 07-25-2017, 08:49 PM   #1
CRMW
2009 swap ECM
1 have a couple of trucks that are equipped the same. 2009 1500wt with 5.3l engines. one of the trucks has the speed limiter adjusted to 89 kph (55mph) and it is getting to be a problem as at that speed the truck won't shift into a higher gear.
I would like to swap the ECM's between the trucks and I'm having problems identifying the procedures for 2007+ trucks.
I would appreciate any assistance on this.
Chris
CRMW is offline   Reply With Quote
Old 08-13-2017, 02:44 AM   #2
truckdude239
truckdude239's Avatar
Re: 2009 swap ECM
I think it would be easlier for you to send tbe ecu out and have the speed limiter removed, either way on an 09 no easy way to swap the ecus as it would need to be programed to the new vin and bcms and vats reprogramed
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
