Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 08-15-2017, 06:40 PM   #201
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
Unfortunately we don't have a way to do that. I believe Jiffy-tite has some types of disconnect fittings that may bridge the gap though.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 09-17-2017, 06:54 PM   #202
SparkyRnD
SparkyRnD's Avatar
back up
Old 09-27-2017, 02:12 PM   #203
Steve Cole
Any chance you could post the specs on your fans? Particularly CFM's and current draw, but the full specs would be nice. Are the fans American made as well? Thanks.
Steve Cole is offline
Old 10-01-2017, 02:25 PM   #204
SparkyRnD
SparkyRnD's Avatar
We have several dozen fans that we carry depending on diameter, depth, speed, etc and it varies on each application. I believe all of the fans are imported.
What we do is get engine / trans / application info, if there are any power adders, what the vehicle is used for, and location information. We use that to determine which fan(s) would be best suited and that is what we recommend. Available space also has a bit to do with it.
Old 10-13-2017, 11:37 AM   #205
SparkyRnD
SparkyRnD's Avatar
bump
Old 10-16-2017, 09:21 PM   #206
truckdude239
truckdude239's Avatar
Have a 71 c10 with 4.8ls 4l60e how much for a radiator and fan set up with the ls ports on passager side and a trans cooler i currently have a griffin ls rad that has sprung a leak after only 4 years which sucks...
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
truckdude239 is offline
Old 10-18-2017, 06:00 PM   #207
SparkyRnD
SparkyRnD's Avatar
David, thanks for contacting us. The price with discount is $425 for the radiator, and we never charge extra for any of the following:
LS configuration ports
Steam Port
Built-in Trans Cooler
For the fans, I'd need to know about how the engine is built (hp & torque), and if there are any power adders (turbo, supercharger, nitrous). Let me know and I can provide recommendations.
Old 10-18-2017, 10:00 PM   #208
truckdude239
Its a stock 4.8l i think it makes 280 hp
David fuller
2000 Tahoe 5.3l 378
Old 10-19-2017, 11:23 AM   #209
SparkyRnD
SparkyRnD's Avatar
Ok, then our standard dual 12's will be fine. That is $220 after discount, and $75 for the controller with relay (not needed if you have a relay set up in your harness for fans). Shipping on that setup will be $55.
Old 11-10-2017, 01:11 PM   #210
SparkyRnD
SparkyRnD's Avatar
thanks for the orders!
Old 11-14-2017, 10:49 PM   #211
carbuff382
carbuff382's Avatar
Hello Sparky,
So I need the LS conversion radiator for my 70, and I have the smaller 3 row metal mounts with the rubber inserts. This will work with your radiator correct? Also, I need the tranny cooler and can you make the intake(upper hose connection the same size as the lower)?
Thanks,
carbuff382 is offline
Old 11-15-2017, 12:25 PM   #212
SparkyRnD
SparkyRnD's Avatar
Yes, that'll work with our setup. We make the LS ports on the passenger side and they are the same size inlet / outlet. We also include a steam port at no additional cost.
Old 11-15-2017, 12:35 PM   #213
carbuff382
carbuff382's Avatar
OK, so how much shipped to 87111 and do you have it in stock?
Thanks,
Old 11-15-2017, 12:55 PM   #214
SparkyRnD
SparkyRnD's Avatar
I had replied to your email earlier as well (but you may not have seen it). We make everything to order, and currently we're on a 1.5-2 week turnaround (maybe a little faster). Shipping is $65, and the radiator (after forum member discount) is $425. Let me know if you'd like to set up an order (I can email you the invoice with payment instructions).
Old 11-15-2017, 01:06 PM   #215
carbuff382
carbuff382's Avatar
Yes, I'd like to get one ordered, also is the core approx. 28" wide? The fan set-up I have is for a minimum of 28" wide core.
Thanks,
Old 11-19-2017, 02:47 PM   #216
SparkyRnD
SparkyRnD's Avatar
Thanks for the order!
Old 11-30-2017, 12:29 PM   #217
carbuff382
carbuff382's Avatar
Hello Sparky,
Sent you an email as well, when should I anticipate receiving my radiator?
Thanks,
Marc
Old 12-03-2017, 02:40 PM   #218
SparkyRnD
SparkyRnD's Avatar
I had replied the other day, but just saw this as well. It'll be shipping out tomorrow and I already emailed tracking and a copy of the invoice.
Old 12-17-2017, 04:18 AM   #219
birkinsb
Looking to get a radiator for a 1970 2wd blazer ls swap 5.3 stock with 4l60 trans would like it with trans cooler , steam port , fans and relay kit to 92807
birkinsb is offline
Old 12-17-2017, 02:12 PM   #220
SparkyRnD
SparkyRnD's Avatar
birkinsb, thanks for contacting us. The price for the radiator is $425 ($450 retail), standard dual 12" fans are $225 ($245 retail), relay kit is $75, and shipping is $80. Total is $805 shipped after discounts.
Note that we never charge extra for a transmission cooler, changing the ports to LS application, or for the steam port. If you would like to proceed with an order, send me a private message with your email address and your full shipping address and I will put together an invoice and email it to you. Thanks and let me know if you have any other questions
Old 12-19-2017, 05:23 PM   #221
sangell
Sent you a PM with my email address and some questions.
sangell is offline
Old 12-22-2017, 11:28 AM   #222
SparkyRnD
SparkyRnD's Avatar
replied, thanks!
Old 12-29-2017, 11:06 AM   #223
SparkyRnD
SparkyRnD's Avatar
bump
Old 01-11-2018, 03:41 PM   #224
SparkyRnD
SparkyRnD's Avatar
back up again
Old 01-25-2018, 03:26 PM   #225
SparkyRnD
SparkyRnD's Avatar
up top
Closed Thread
