![]() Join Date: May 2010
Can Someone ID This Fan?
If I recall correctly, I found it uninstalled in one of our trucks. It's a little too big for a small block shroud.
Thanks! |
#2 | |
Before and After
Re: Can Someone ID This Fan?
Haha, couldn't help myself. It wouldn't tell me, i guess you will have to wait for someone who isn't a smart @ss for the correct info.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
That's actually pretty clever!
...and thanks for bringing this back to the top. |
Any markings or numbers on either the fan or clutch? Without that, its pretty much a shot in the dark.
.........Always been a REALLY BIG FAN !!! ... of these 7 blade fans. I have 'em on both of my trucks... little smaller diameter though. Both trucks have SB sized shrouds. Don't know what yours came on but Advance, Oreilly and others have different diameter blades & replacement clutches and they aren't expensive.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds Both my trucks have A/C and I don't have heating problems in central FL.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
Moderator
![]() Join Date: Jun 2017
Looks like a standard HD 19" 7 blade fan fitted to most AC equipped 70 on Chevy's....and GMC's...both cars and trucks.
Never been a BIG FAN of anything other than Chevy's and GMC's ![]() ![]() ![]() ![]() ![]() ![]() |
#7 | |
I does appear to be a FANtastic fan. |
laying low
![]() Join Date: Mar 2001
I thought it might be for the 67-72 big block application but advance says no. Then i changed search to a 75 big block c30 application and still no. 19 1/2" is big. My 5 blade OE small block fan is 18". How large is the fan opening in a 67-72 big block fan shroud?
I just installed that fan and a new hub in my 1970 c10 small block ,bot it at swap meet marked big block they all swap back and forth also installed a shroud ,have no clue what it fits but it works ,still runs hot so am installing bigger core rad
i have same fan on 78 k1500 454 works excellent
Moderator
Hey tlman,
Make sure you have a thermostat in place...leaving it out results in the water flowing too fast through the radiator for it to cool correctly. Just a suggestion...stay safe and KOOL... ![]() ![]() ![]() |
ya know all about that ,learned that in the 70s (im that old ) and I also own heavy truck shop in Canada so any how ,went and seen some road trains in perth this year too ,daughter lives there ,where you from ?
Moderator
I'm that mature as well...1952 model here...
Born and raised in Sydney...resident in Cherryville NC now for 5 years.... Have a good one ![]() ![]() ![]() |
you too
