08-17-2017, 07:08 PM | #1 |
Before and After
Who is running 22" Transits with a drop?
I came across a set of cheap transits, I am bagging my C-10 at the moment, I am wondering if running transits with a large drop is an issue with the front suspension? or rear?
I currently have 5 bolt running gear, I was thinking about having the option of running the 22" with 1-1/2" wide wheel adapters. is this the right width? I have made measurements and think it should work, but I am working with the frame alone, then have the bed off as well as the front clip to measure from, this is not always accurate, so i am relying on those who have attempted this already for insight.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
08-17-2017, 11:39 PM | #2 |
Re: Who is running 22" Transits with a drop?
I'm guessing nobody is running transits without a drop. on my 70 I have 2" drop spindles, bags all around. 6bolt disc upgrade in front. On the front the transits fit fine but would look better if they were pushed out a bit. On the back I flipped the centers to get the right backspace without spacers. If I remember correctly I used Honda Pilot studs, m14x1.5. Bags are just manual but I run things pretty low.
08-18-2017, 08:27 AM | #3 |
My truck is static but it is pretty low. On the front, there's no way you could run a 1.5" spacer. I don't have drop spindles yet, but with those the wheels will sit nicely under the fender with enough room to turn. Then you are stuck with the 5 lug problem though. The guy I got my transits from also does bolt pattern swaps on them and can do a 5 lug swap. It's not cheap though.
On the rear, I also did what t300 did and flipped the centers so I have 4" of backspace on the rear wheels instead of the 6" they come with. On a '70 you will most likely have the wider rear end which means you could run a 1.5" spacer max.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
08-18-2017, 10:15 AM | #4 |
I'm running them on a '69 swb with the 1.5 spacers all the way around with a 2/3 drop and don't have any problems.
08-18-2017, 11:09 AM | #5 |
Id love some but so much $$ for steel wheels, then tires...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-18-2017, 03:23 PM | #6 |
hewittca , how did you mount your hubcaps
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-18-2017, 11:35 PM | #7 | |
Before and After
What gear ratio are you running? Do you have an Overdrive trans??
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA Last edited by WB72; 08-19-2017 at 12:15 AM. |
08-18-2017, 11:44 PM | #8 | |
Before and After
I can get another set of disks, I have another set of axles I could put in the rear end as well. I will have to measure my rear ends, I wasn't aware that there are different widths of rear ends.
