Old 07-17-2017, 09:43 PM   #1326
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by 69gmcc10 View Post
That is a good looking intake setup. I hear that the flat planes are the way to go for fuel injection because the similar length runners make for a more consistent afr across all cylinders. It is also nice you can use your stock injectors, even though that wont matter when you add boost to it a year after you get the truck up and running again. ... actually, I give it 6 months!.... your are probably doing it already....
Guys, keep your eyes open on the ls classified section! There is going to be a sweet holly LS intake up for sale soon!
How is it you're in my brain? I could keep the intake setup with a turbo...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-17-2017, 10:39 PM   #1327
kehstr
kehstr's Avatar
but if you go the supercharger route.....
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 07-19-2017, 04:44 PM   #1328
69gmcc10
69gmcc10's Avatar
I am under the impression the injector will run out of flow quickly when you boost it. I could be wrong... happened once...
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 08-18-2017, 04:06 PM   #1329
zacthrasher
zacthrasher's Avatar
Just read your thread front to back and back to front....good stuff! I myself have been going through a year and half of thoughts of to tear it back apart and redo all suspension....but I can't decide what stance I want. Probably will go with a PB coil over mild.
The thought of having to move the bed floor and more bothers me....any ways glad to know I am not the only one going through painstaking thought and never being quite finished with an already good truck.
My 67 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=473825
zacthrasher is offline   Reply With Quote
Old 08-20-2017, 11:47 AM   #1330
gringoloco
A guy with a truck
gringoloco's Avatar
Roots-blown LS? Hmmm...
Yeah, bigger injectors and I tune would be in order, for sure. The new Holley turbo manifolds sure look nice, though...
Thanks for the compliment! If you're a tinkerer like me, they're never done. Working on it is half the fun
-Chris
Old 08-20-2017, 12:01 PM   #1331
gringoloco
A guy with a truck
gringoloco's Avatar
Dropping some photos in here for comparison later. This is how she sits currently:
The beer (I use that term loosely) can is 5" tall. I hope to gain a couple inches of ground clearance here.
Under the cab mounts measures approx 7.5" front and 8.5" rear. I'd like to lose a few inches here, ultimately.
...and it's filthy under there!
-Chris
Old 08-20-2017, 12:07 PM   #1332
gringoloco
A guy with a truck
gringoloco's Avatar
Here's the height measurements at the highest point of the wheel arches. Again, I'm looking to reduce these numbers by a few inches, and hopefully even them out side-to-side, with the adjustability of the coilovers.
LF - 27 3/8"
RF - 27 1/8"
LR - 27 7/8"
RR - 27 5/8"
-Chris
Old 08-20-2017, 12:36 PM   #1333
gringoloco
A guy with a truck
gringoloco's Avatar
...and here we go...
-Chris
Old 08-20-2017, 08:30 PM   #1334
gringoloco
A guy with a truck
gringoloco's Avatar
Spent a couple hours tearing the bed apart today, instead of just taking it off in one piece, as I'll have to raise the floor before re-installation. Had more broken and seized bolts than expected, since I just put this thing together a few years ago. Percentage-wise, not so bad as there are a LOT of bolts holding these beds on/together.
Super dirty underneath, so I'll pull it back off the stands and outside to clean it up before working on it any further. Gratuitous, not-so exciting pics:
-Chris
Old 08-20-2017, 08:55 PM   #1335
smbrouss70
smbrouss70's Avatar
Glad to see you working on it! Unfortunately, they do get dirty when you drive them...
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-21-2017, 11:34 AM   #1336
gringoloco
A guy with a truck
gringoloco's Avatar
Good to be finally digging in! I wasn't expecting quite so much filth; guess three years in TN took its toll. I'll get after it with a scrub brush and some dish soap soon enough. I like to work on clean cars...
-Chris
Old 08-21-2017, 11:30 PM   #1337
gringoloco
A guy with a truck
gringoloco's Avatar
Dragged her outside for a pressure washer bath. She looks good with the sun setting, even missing parts. Much more accommodating place to work now--looks so nice it's almost a shame to cut it all out, almost...
-Chris
Old 08-21-2017, 11:36 PM   #1338
gringoloco
A guy with a truck
gringoloco's Avatar
...and a quick mockup of one notch, 'cause I couldn't resist...
-Chris
Old 08-26-2017, 10:25 PM   #1339
gringoloco
A guy with a truck
gringoloco's Avatar
Welp, she's getting naked, slowly. What a tease...
Lots of stuff will be for sale on the parts board, soon. The CPP notches will stay bolted in a bit longer to help hold things together while I pound rivets out of the crossmembers. I hope it all goes back together as easy as it comes apart!
-Chris
Old 08-27-2017, 01:08 AM   #1340
rustytruck50
rustytruck50's Avatar
I love this truck....it just gets better with the passage of time!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 08-27-2017, 08:51 PM   #1341
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, though I feel like I'm moving backward lately
More "progress" as the framerails are now completely bare and the demons (rivets) have been exorcised! Hovercraft conversion complete; now time to start bolting things back on
-Chris
Old 08-28-2017, 09:48 AM   #1342
SCOTI
SCOTI's Avatar
Nicely done buddy. Watching the progress.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-28-2017, 02:03 PM   #1343
67ChevyRedneck
67ChevyRedneck's Avatar
https://www.youtube.com/watch?v=qtK0KMH-8xs
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-28-2017, 02:08 PM   #1344
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks Scot!
Originally Posted by 67ChevyRedneck View Post
That's almost exactly my 5-yo's reaction yesterday when he came out to help
-Chris
Old 08-28-2017, 02:15 PM   #1345
rustytruck50
-Doug
'05 RCSB Sierra 2WD
Old 08-28-2017, 06:10 PM   #1346
Rochlow
Always love a Gringo build..
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 08-29-2017, 02:12 PM   #1347
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, Jeff! Kind of enjoying it myself
A few pretty nice pieces I've pulled that will be on the parts board, soon:
-Chris
Old 08-29-2017, 11:37 PM   #1348
gringoloco
A guy with a truck
gringoloco's Avatar
...and the new parts laid out for inventory. Reminds me of building plastic models as a kid. I love this shade of powder called evo grey from prismatic--it flops from near black to silver depending on light. Ready to start bolting this stuff on. Or just break out the xacto blade and testors glue...
-Chris
Old 08-30-2017, 08:28 PM   #1349
rustytruck50
That's a sweet looking bunch of parts!!!!
-Doug
'05 RCSB Sierra 2WD
Old 08-30-2017, 11:51 PM   #1350
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks buddy! Trying to turn it into a sweet looking (and driving) truck sometime soon. This is at least the third dropmember I've purchased for this truck--I intend on making it happen this time!
-Chris
