Old 08-21-2017, 06:28 PM   #1
elswickaj
elswickaj's Avatar
Eaton HO52 SWAP???
Hello everyone,
I am on my first project and my 1972 K-20 Camper Special has Eaton H052 rear axles. I was informed parts are near impossible to find and a upgrade would be the best way to go. I have heard DANA 60 and 14 bolt. My question is what rear axles are out there that will bolt directly up? I wont be using the truck for any major hauling etc... but want to keep it a true 3/4 ton. I am also sure this question has been answered 100 times but couldn't find it. New to the site lol.
elswickaj is offline   Reply With Quote
Old 08-21-2017, 06:56 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Eaton HO52 SWAP???
Welcome aboard! Pretty sure most (if not all) bearings & seals are readily available, as well as brake shoes & hardware kits. Brake drums and gearsets are harder to find but if yours are still good..... Those Eatons are tough as nails and if nothing is wrong with it, why not keep it? Sorry this doesn't answer your question but I'm sure others will jump in with better info.
EDIT: Just in case this old thread has info that might be useful to you: http://67-72chevytrucks.com/vboard/s...d.php?t=536119
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-21-2017, 07:16 PM   #3
elswickaj
elswickaj's Avatar
I agree and have a lot of the parts bearings, inner, outer, and brakes including the hubs and drums. I didn't want to change all that and 6 months down the road like you said the gear set take a crap on me. I was thinking for the future of the truck and expenses. It would be a shame to do all that work and not be able to sell it or return anything.
Old 08-21-2017, 07:31 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Well, that is true. In 40 years my HO52 had a pinion pocket bearing fail and NAPA had it. Other than that it has only needed brake shoes & hardware and wheel cylinders, and fresh oil. I'll keep it and if it has a catastrophic failure down the road, I'll be asking the same questions you are!
Someone will ask to see pics of your truck, so it might as well be me. Love those K20s!
- Mike -
RIP El Jay
Old 08-21-2017, 07:39 PM   #5
jeffahart
jeffahart's Avatar
If you get a GM 1ton corp 14 it should bolt in without changing the perches. You will need to weld in shock tabs. I ended up 5/8" shorter Yoke to yoke with ORD zero rates at the 1" hole. And I think I used Driver side Parking brake cables on both sides. search on 1970 K20 axle swap, I have what I did in a thread. Easy money.
White K20
jeffahart is offline   Reply With Quote
Old 08-22-2017, 01:37 AM   #6
'63GENIII
'63GENIII's Avatar
Id pop the 3rd member and get a good look at it first. Maybe even take it in to a shop that can set up gears correctly? 14 bolts and Dana 60s are great axles but may also need a good going through is neglected by the PO.
Whenever possible, I try and work with what I have until it becomes more cost effective to do something else.
That said, the 14B went into the '63 with a little bit of work. Shock mounts as Jeff mentioned, driveshaft cut and e brake cable figuring outing. The original 12 bolt was evicted for a Dana 60 (that was hammered when I got it).
Had an Eaton been under it to begin with, I might have tried a little harder to save it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-22-2017, 01:54 PM   #7
Bigdav160
Bigdav160's Avatar
I had to move the spring perches on my 14 bolt (1975 model) to get the pinion angle correct.
YMMV
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-22-2017, 05:19 PM   #8
elswickaj
elswickaj's Avatar
I appreciate all you guys input, however, today I took the differential cover off and the gears look new, pinion has zero slack and they are 4.10 gears. I am going to take my chances and use this until she breaks then think about the upgrade. I have a feeling I can get 5 years out of this on with no worries. I am liking the **** out of this forum and will post a picture ASAP. Thanks again guys.
Old 08-22-2017, 06:00 PM   #9
dozerbill72
dozerbill72's Avatar
If you break it please post pics. I've ran these for 30 years now in pull trucks, wheeling rigs and even put one in a '91 Cummins Dodge because I had it and couldn't afford to rebuild the Dana70 that the pinion twisted off of. The one in the Dodge last I heard had over 300K miles on it. Just service it and run it.
dozerbill72 is offline   Reply With Quote
Old 08-22-2017, 06:27 PM   #10
b454rat
I bolted in a front 44 from a mid 70s GM, and bolted in a rear 60 from a 78/79 Ford....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 08-22-2017, 07:48 PM   #11
jeffahart
jeffahart's Avatar
For sure, run it till it quits, it will probably last as long as you need it. Bottom line is; you have options galore if and when the time comes to replace. Especially if you are looking for a rear axle, they are everywhere. Fronts are a bit more dicey, you have a limited supply because not all trucks are 4x4 and you have more on them that can be junk, like ball joints and such. But I'm just pointing out the obvious now!
Also, welcome to the forum.
White K20
Old 08-23-2017, 12:45 AM   #12
'63GENIII
'63GENIII's Avatar
I love it when things work out like that! Although I really don't have much experience with those types of situations
Chris
'63 k15 long step
Old 08-23-2017, 12:49 AM   #13
'63GENIII
'63GENIII's Avatar
And yes.... Welcome to the forum!
Now where are those damn pics???
Chris
'63 k15 long step
Old 08-23-2017, 07:52 AM   #14
Is your HO52 broke? If it ain't broke, don't fix it. Unless your axle needs repair, you have no reason to believe it will. There are plenty of used parts from all the axles that get pulled for a swap. Bearings and seals are available, so if you are concerned about the age and durability, replace all those and prevent any ring & pinion issues. Brakes? Maybe not available, haven't tried lately. Buy last time I did brakes I was able to get everything from NAPA. If not, isn't the trend to go to disc brakes anyway?
Old 08-25-2017, 06:03 PM   #15
elswickaj
elswickaj's Avatar
Here she is guys, needs some love for sure.
Old 08-25-2017, 07:55 PM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: Eaton HO52 SWAP???
Nothing wrong with that, I see an honest-to-goodness truck with a little hard-earned wear & tear, just like a K20 should have. With three tanks and stout axles, it has solid bones and tons of potential if you decide to change things around a bit. Congrats!
- Mike -
RIP El Jay
Old 08-26-2017, 08:58 AM   #17
Yeah, Lots to love there! I'd own it.
Old 08-26-2017, 09:45 PM   #18
Short 3/4
Back in 1985 we had a 62 camper special in the fleet at work that finally died. The boss let me have the rear end for free, so I put it on my 66 C10 and made it into a 3/4 ton. I used and abused that 66 as a work truck until last year when it finally rusted away.I now have that same Eaton bolted to my new project, a 65 K10, so now that rear end has outlived two trucks and is still going strong! In the late 80's I had Randy's Ring& Pinion install a NoSpin in it and at the time they said the diff was pretty worn and probably only had a few more years left. Well, that was 30 years ago. I'm not sure you can kill an HO52. You have a great truck there and that Eaton will serve it well. If you ever get rid of it I'll be glad to take those 4.10 gears off your hands. Good luck with your project - Tom
Short 3/4 is offline   Reply With Quote
Old 09-21-2017, 02:52 PM   #19
OldCreek
OldCreek's Avatar
Keep the H052.
I found everything i needed when i rebuilt mine. Including all brake parts, bearings and seals. My local axle specialist even had a set of ring/pinion gears to replace mine.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 09-26-2017, 10:21 PM   #20
Short 3/4
Originally Posted by OldCreek View Post
Keep the H052.
Wondering where you got your parts as sounds like we're in same part of the world ( "Old Creek" makes me think Cayucos). Always looking for sources. Thanks, Tom
-hope this is not considered a highjack, but had to ask
Old 09-27-2017, 01:13 AM   #21
OldCreek
OldCreek's Avatar
Yep! You got it.
I got my axles done at American Gear in SLO. (Great name, great service!) I don't suspect he has tons of "rare" parts but, hey, he had what i needed. The point being, an H052 has value.
Wil
Old 09-27-2017, 10:33 PM   #22
Short 3/4
Yep! You got it.
Wil
I know the shop, but have never used them, nice to know they are good people. I've seen an 8 lug Blazer around town but never noticed it had an HO52, that's very cool!
Hopefully we have all convinced this guy to keep that axle where it belongs and stop another nice HO52 from being turned into a boat anchor.
