#5726 |
Re: What did you do to your truck today? Chapter II
I have spent the day cleaning up two of my "Custom 10" emblems. Paint stripper and Bar Keeper's Friend worked great on the one and Goo Gone is doing a fair job (slow though) on the other.
Apparently a previous owner used a caulk-like or silicon substance to help it adhere to his truck at some point. Last edited by In The Ten Ring; 08-27-2017 at 05:30 PM. |
#5727 |
I'm amazed that the disc brake conversion is there .
I'm hoping to find a wrecked/rusted out Suburban with the larger drum brakes to put on my '69 C/10 but I'da prolly grabbed this disc bake kit the instant I saw it . -Nate |
#5728 |
Junior Member
![]() Join Date: Jul 2017
today I ordered everything to Create my own Brake lines and Fuel lines I discovered 5 leaks in the lines I am going to be taking the cab and the bed off soon so might as well put in the rear gas tank and new lines.
#5729 |
![]() Join Date: Dec 2003
I drew up and water jet cut a piece of aluminum for my Speedhut gauges. I think it turned out pretty cool. just cut the old plastic out and riveted on the new panel. easy peasy.
https://www.ebay.com/itm/295742064443 |
#5730 |
Junior Member
what did the Gauges cost you and do you have a link?
#5731 |
![]() Join Date: Feb 2009
This E-brake hardware cleaned up nicely. Less the clips anyway. I'll have a pot of new nuts and washers to use, but somehow I end up cleaning up the old anyway.
Sure takes a while, but white vinegar & WD-40 hasn't failed me yet. I'll have these black zinc plated or phosphate coated.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#5732 |
I don't have a link.. it's just the 4" gps speedo and 4" tach. the rest i think are 2-5/8".
Speedhut is the brand.
#5733 |
All I got done today was more cleaning up on a used fender emblem. Evaporust soak took off all the road grime the silicon caulk had trapped. I got nearly all the rust off it too, some seems trapped in the pores.
I want to do more caulk removal before injecting the nail polish. |
#5734 |
![]() Join Date: Dec 2012
I just put on a set of Taylor cut-to-fit wires with Moroso wire looms, (was having issues with a few wires being too short and laying across the valve covers). Seemed to turn out good!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#5735 |
![]() Join Date: Feb 2007
Drove it. I've been having issues with the truck shutting down. Surprisingly, it is RPM noise from the MSD ignition box affecting the pickup wire for the FiTech efi system. I tore my wiring harness apart, separated the wiring between the efi and ignition and now it's running well again. Very interesting but frustrating too.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#5736 |
Got the amp guage working...not real exciting. Bearly moves with the power turned on. Thinking about upgrading to the 76+ volt meter kit. Have to find out how extensive the modification is to the cluster.
1970 C10 Short Stepper with 71/72 front clip. |
#5737 | |
I how is the braking without power brakes?
#5738 |
Not that bad. Takes some effort of course, but no problem stopping. I'm a little wary on these crazy freeways out here though.
#5739 |
A little more cleaning on the emblem, more of the of the caulk came off. Just what's around one stud left now. It's back into Evaporust soak.
#5740 |
snj8198, I tried to send you a message on the fitech unit but your in box is full
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#5741 |
I added a stock power booster to my '69 SB, it really reducexd the pedal effort a lot .
Now, even SWMBO can drive it although she refuses to do so ![]()
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#5742 |
Still cleaning the emblem and making great progress! Nearly all of the old caulk is off now, just a tiny bit left in a crevice.
#5743 |
![]() Join Date: Oct 2014
Not so much what I did to my truck as what I did for my truck. Just got done ordering a new AC Delco HEI distributor and a pair of United Pacific LED tail light assemblies. The old girl's a money pit but I love her just the same.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#5744 | |
Moderator
![]() Join Date: Jun 2017
![]() ![]() you are talking about your truck now ? ![]() ![]() |
#5745 |
Well of course. LOL
#5746 |
How could you not?
#5747 |
Replaced the useless brass float that came with my fuel level sending unit with a plastic float out of a Jeep CJ. The lack of quality control at these aftermarket manufacturers continues to amaze me.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
#5748 |
Interesting as modern plastic floats often get soggy with ethanol and sink .
Doesn't TOMCO (NAPA) still make good brass ones ? .
#5749 |
Among other things, I learned how to manually turn an engine. I pulled the plugs & gave the cylinders a shot of fog oil.............................Turning the crank pulley by hand is a real ball buster for this frame, but it works. However, this tool on the flex plate makes it super easy. Another board member recommended it. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#5750 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Carby Floats
I just bought a NAPA carb kit for my 72 with the original Q-Jetand it had the brass float and my friend doing the carb was surprised the float was brass..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
