Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-08-2017, 06:29 PM   #51
nlped
nlped's Avatar
Re: Finally...a new shop at the house
Today's progress...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-18-2017, 07:34 PM   #52
nlped
nlped's Avatar
A few day to day updates....
Carter
Old 09-18-2017, 07:35 PM   #53
nlped
nlped's Avatar
Then...
Carter
Old 09-18-2017, 07:37 PM   #54
nlped
nlped's Avatar
Following day...
Carter
Old 09-18-2017, 07:39 PM   #55
nlped
nlped's Avatar
And as of today... all the exterior walls are up. Will start in the roof tomorrow. Hope to have the roof, trim & garage doors in place by the end of the day Friday. #fingerscrossed
Carter
Old 09-18-2017, 07:53 PM   #56
Clyde65
Clyde65's Avatar
Nice!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-18-2017, 08:36 PM   #57
nlped
nlped's Avatar
^^^Thanks! I'm excited to finally be moving forward. It's been a 3 year journey that has been riddled with bumps and bruises, but looks like I'm finally going to at least have some dry storage. Power is next, then drainage and backfill of the block wall... THEN move-in.
Carter
Old 09-18-2017, 08:55 PM   #58
flashed
Wow ,you are getting close ,looking great too.
flashed is offline   Reply With Quote
Old 09-20-2017, 08:28 PM   #59
nlped
nlped's Avatar
Hopefully just a few more days & I'll at least have a completed structure.
Carter
Old 09-21-2017, 07:47 PM   #60
nlped
nlped's Avatar
Today's progress... should have the roll-up doors soon, possibly tomorrow...
Carter
Old 09-22-2017, 08:29 PM   #61
Advanced Design
Advanced Design's Avatar
Your new building is looking very good! What are the dimensions again?
Advanced Design is offline   Reply With Quote
Old 09-23-2017, 08:45 AM   #62
nlped
nlped's Avatar
It's 36'x46'x14'. It's as big as I could fit in that spot. I'm already sure it needs to be bigger.
I'll be pressure washing the floor today & then putting the sealer down tonight (if all goes well).
Carter
Old 11-26-2017, 08:17 PM   #63
nlped
nlped's Avatar
I’ve been plugging along...
200 amp service... done
Floors pressure washed & sealed... done
12’x14’ loft for wifie poo’s stuff... done
Pallet racking... done
Rotary 9000 lb xL lift... lift is bought & in the shop, but not up yet. Hopefully that’ll happen this weekend.
Carter
Old 02-19-2018, 11:34 PM   #64
nlped
nlped's Avatar
Well... the lift still isn’t up! Marked the 1st 2 holes on the left tower and drilled the 3/4” hole...only to find out that the 6” pad that I paid for was only 3-3/4” thick!!! So I ended up cutting out a 15’-6” x 5’ hole into the existing floor and dug it down to 14” deep (including digging out an additional + 4” under the existing slab) added 4” of gravel base, plus 100’ of 1/2” rebar. I got the new repair poured this last Friday (4K concrete + added fiberglass reinforcement). 25 days from today...Lift should go up. I’ve been concentrating on working on the electrical and organizing.
The dogleg in the picture is where I ‘absorbed’ an existing crack in the current slab. I’m just trying to make lemons!
Carter
Old 02-20-2018, 08:29 AM   #65
PGSigns
PGSigns's Avatar
Sucks you had to cut the floor. One thing for sure the piece you put in there will not come up short when you drill the holes.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-20-2018, 04:12 PM   #66
nlped
nlped's Avatar
Jimmy
It did suck! Concrete saw (aka 10” skill saw with a diamond blade) a jackhammer, then 2.7 million wheelbarrow loads of concrete, gravel & finally clay and more rock. Then I got it all ready for new concrete (almost 9 yards).
Now that I have to wait another 24 days for the concrete to cure, I’m working hard & heavy on the electrical, lighting & cleaning/organizing. Hopefully, I’ll be all done with that part when it comes time to install the lift. Maybe I’ll get my compressor and related parts installed too.
Carter
Old 03-11-2018, 07:33 PM   #67
nlped
nlped's Avatar
Well, I’ve gotten a lot of the electrical done. I got two 100 amp subpanels wired in (1 up on the loft & 1 in the rear), lights & fans under the loft (the gym) & the overhead lighting.
Sorry the pic is sideways.
Carter
Old 03-11-2018, 08:54 PM   #68
Advanced Design
Great progress. Nice lighting too. Are those T5?
Old 03-11-2018, 09:12 PM   #69
nlped
nlped's Avatar
Thanks Doug! No, They’re T8 actually. I got them for free from work...they were putting in new LED fixtures. They had 277 ballasts, but I did away with the ballasts and converted to 18W 6000k LED’s. Really lit the place up.
Carter
Old 03-27-2018, 08:11 PM   #70
nlped
nlped's Avatar
Lift is IN!!! What a pita to do by myself!
Carter
Old 03-27-2018, 08:13 PM   #71
nlped
nlped's Avatar
I also grabbed some Gladiator cabinets off the List of Craig and got them mounted
Carter
Old 03-27-2018, 09:01 PM   #72
nlped
nlped's Avatar
I also grabbed some Gladiator cabinets off the List of Craig and mounted them.
Carter
Old 04-01-2018, 05:50 PM   #73
nlped
nlped's Avatar
I finally got a couple of the projects into the work space.
Carter
Old 04-01-2018, 06:23 PM   #74
flashed
Looking good in there .
Old 04-01-2018, 07:06 PM   #75
Advanced Design
Congratulations! Coming together very nice! The cabinets were a good score.
