09-21-2017, 11:41 PM | #1 |
front license plate bracket
The state I live in requires all vehicles to have a front license plate. The factory bracket seems to be a plate mounted on the passenger side but I don't much care for this setup. So, I was wondering who else have plates on the front of your truck and how you mounted them, pictures would be great.
Here is a picture of what seems to be the factory setup. I have the bracket, but I can't find any place for mounting it except to drill new holes. |
09-22-2017, 01:01 AM | #2 |
Re: front license plate bracket
Build a bracket that runs out under the bumper and turns up to mount the plate You might have to run back to the front cross piece of the frame if there isn't something to mount to behind the bumper. Mount the plate so it overs the bracket from head on views like the one you posted.
Can you run a piece of flat bar between the two bottom Bolts so it bolts to those bolts and has a piece that loops around the bottom of the bumper for the plate mount? It's been so long since I have been under one of those trucks that I don't remember what it looks like under there.
09-22-2017, 01:30 AM | #3 |
I was hoping someone had modified a center plate bracket and could tell me what they used. Something along this line that could be filed to fit, only not plastic.
09-22-2017, 01:42 AM | #4 |
I don't think you need anything that elaborate.
I don't have my doodle pad handy but think a piece of 1/4x1-1/2 flat bar (could be narrower) bolted to the two bottom bumper bolts. Then visualize two pieces of the same flat bar bent in a C shape curving around under the bumper and running out just past the front most point of the bumper. Now weld a piece of angle that is the same length as the license plate or just shorter to those C shape pieces with two holes to bolt the plate to. You want it just far enough in front of the bumper so the plate doesn't vibrate against the bumper. Or you could make your angle out of a plate size piece of 1/8 plate with a 90 at the bottom to weld to the C shape pieces. No fuss, 10 buck or less investment and if the plan ever changes easily removable with no marks left behind.
09-22-2017, 01:58 AM | #5 |
This guy just bolted the plate on. It is in the right spot, but I would like the plate mounted to something that fits the bumper.
09-22-2017, 02:52 AM | #6 |
it wouldnt be hard to fab a box style bracket similar to the plastic one you showed...make it from 1/8" aluminum and contour the ends to fit your bumper...about any sheetmetal shop could knock that out quick....another option is one like this from summit....https://www.summitracing.com/search?...&keyword=59388
09-22-2017, 08:32 AM | #7 |
Building a bracket is an option, I have access to a metal shop. I was hoping for one I could just modify, what have other done for a fabricated one?
09-22-2017, 10:21 AM | #8 |
If you arent 100% certain you want to even run a front plate, I would call and make sure its 100% required, I looked over the montana law briefly and it looks like 61-3-301 allows a single rear only plate for vehicles over 30 years old. There are some requirements listed though that make it more complicated than that so maybe look at section d at this link http://leg.mt.gov/bills/mca/61/3/61-3-320.htm
also there are states that require two plates that exempt vehicles that dont come from the factory with a front plate holder. if you want to run a front plate I would just get some 16ga and bend up a bracket with a plate mount. I personally like the front plate mounts, whenever I get a truck with one I always run a novelty plate on the front.
09-22-2017, 11:02 AM | #9 |
I checked into the requirements and found them vague at best and confusing for sure. Maybe my best course of action is to wait and see if the police think a 1957 Chevy pickup truck needs a front license plate to help with Identification. I will just wait for now because I would rather not have a license plate on the front.
09-22-2017, 12:26 PM | #10 |
Well you can buy a Montana street rod license plate and run a single rear plate according to this. http://leg.mt.gov/bills/mca/61/3/61-3-301.htm
I'm not a big fan of YOM, antique/classic or street rod plates simply because of the restrictions that are put on them by the state. Get the wrong cop pulling you over because you are hauling a load of stuff in the back with street rod plates and you might get a big ticket and could loose the use of the plate. I'd rather just stick the plate in the cab either on the dash or somewhere within easy reach and if I got pulled over for no front plate tell the officer that you have a new bracket ordered but it hasn't come in yet. That may or may not work. From my own personal experience not having a front plate is one of the fastest ways to draw a cop's attention and get pulled over. I only got pulled over once for speeding in my 48 over a 20 year period but got pulled over for no front plate every time I left the plate off or didn't have the plate and bumper bolted on. Had the bumper with the plate on it in the back that time as I was headed to my buddy's place to get him to help me put it on. The state patrol here is death on no front plate.
09-22-2017, 01:17 PM | #11 |
55-57 Ran the plate off to one side. 58-59 had them centered . You can buy a repo of the original bracket for $12-$15 from all the aftermarket vendors. I woul have a used original for $14 .
09-22-2017, 05:02 PM | #12 |
I plan to fab up something that conforms to the curve of the front bumper and install rare earth magnets from Harbor Freight. I'll put it on to drive around and take it off when parked.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-22-2017, 06:34 PM | #13 | |
the law you posted references the law I posted, which is why I posted it, and it states that old vehicles 30+ years old dont have to run a front plate if they meet the criteria in section d. he shouldnt need to apply for a street rod license plate, he may already be in compliance. I am familiar with the street rod desingnation here in kansas and also in pa, both states dont allow antique registration and taxes for street rods. so its not a minor point, at least in those two states.
09-22-2017, 07:03 PM | #14 |
There are some real junker cars and trucks cruising the roads here in Montana. No vehicle inspections that I know of, maybe some of the larger cities but I don't think so. Hard to say if the law enforcement will care about a front plate. I could set the plate on the dash, but I doubt that would appease a cop if he pulled me over. Still, I doubt he would write me a ticket.
I would mount the plate if I could come up with something I liked. The factory bracket has the plate sticking up in the air....nope, not for me. Centered on the bumper is ok, if it comes out looking nice, but I haven't seen anything so far. I will keep looking and maybe something will come along. |
09-22-2017, 11:11 PM | #15 | |
If you must run a front plate, it wouldn't take much to fab a bracket beneath the front bumper to avoid drilling visible holes in the bumper |
09-23-2017, 01:50 PM | #16 |
Thanks to all for the advice and checking the Montana codes. I would like to avoid any problems, so I will continue to decide how I want to install the front plate. Maybe I will continue with the rat rod look and just drill holes and bolt the license on......
09-23-2017, 01:54 PM | #17 |
this may sound a bit nuts but they sell license plate retractors --usually used in the back -maybe you can modify one to use in the front
09-23-2017, 01:58 PM | #18 |
License-Plate-Re-tractor-Kit-with-One-Touch-Switch
09-23-2017, 02:06 PM | #19 |
I don't mind having a license plate, if it looks nice. Most of what I have seen so far I haven't cared much for. I would leave it off though, if I could. The bumper is the original and we had to heat the bottom and bend it back into shape from a botched tow job at sometime in the past, so I am not out much if I need to get a new bumper.
(maybe I should have used the bumper with the "nifty" grill guard.) |
09-23-2017, 08:02 PM | #20 |
Ol story but All I can say is i got pulled over for having my rear plate exactly where GM put it on my 54 3100. Under tailgate above bumper in the area designed for it. Got cited after stopping to assist in an accident. HAd to take an original 1954 brochure to court and show the judge who tossed the case, The dumb ass officer was pissed.
Speaking of police the redlight and speed cameras are inspiring a whole world of new electronic warfare technology including digital plates, blank outs and other "defenses". This addition to new gps and radar detection that verbally warn "cameras ahead!!" . The latter could be linked to plate concealment or blank-out mechanisms. Just saying think ahead in technology. Last edited by vintovka; 09-23-2017 at 08:12 PM. |
09-23-2017, 08:46 PM | #21 |
We are getting new technology all the time here in the town I live in on the western side of Montana. We now have five stop lights and two of them have traffic activation....
I can't imagine the cop would cite you after stopping to assist at an accident, he must have been having a bad day for sure. There are traffic cameras in Spokane and I will take a look at what is available for detection systems. Thanks vintovka |
09-23-2017, 10:01 PM | #22 | |
09-26-2017, 11:41 PM | #23 |
On my '57 GMC the bracket mounts to the lower edge of the bumper in the center.
Here's the bracket for a '57 Chevy Car. You can get it from http://fillingstation.com Part # DC608B $ 17.95
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 09-26-2017 at 11:47 PM. |
09-27-2017, 02:59 PM | #24 |
Thanks for the link. I might already have the bracket since the front of my truck, the fenders, came off of a 1956 GMC. My truck is lowered quite a bit and may need the plate to be higher.
09-27-2017, 07:20 PM | #25 |
The pic of the bracket shows it upside down.
Turn it over and mount the plate by the bottom holes and it should line up with the line in the bumper.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
