Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-01-2017, 11:08 PM   #1
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
If the water pump is the original for the '89 TA, it is a reverse rotation for a serpentine drive assembly.If you don't want to run a serpentine drive, you will have to change the water pump. At that point you may as well get a short water pump, which is correct for your truck.
Originally Posted by superfly66 View Post
Thanks for setting me straight on the motor. Haha. It looks like I had some other info wrong. I actually have a long water pump and not a short water pump. Back to the drawing board on the bracket I need.
Old 10-11-2017, 09:11 PM   #2
superfly66
I purchased brackets for saginaw type P/S pump. The pump I have says metric on it and didtn realize it until I removed the pulley. Now I have the wrong brackets. Should I buy a saginaw type P/S pump because I cant find brackets for this type of pump. Refresher: The PS parts are off of an 83 C10. The original mount which I dont have, was told by the PO that it also held the compressor as well as the P/S pump. TIA
superfly66 is offline   Reply With Quote
