TNT-MOTORSPORTS
Wilwood master cylinder's and combination prop valve
Wilwood has packaged the popular Aluminum Tandem Chamber Master Cylinder with the Combination Proportioning Valve, mounting bracket, fluid tubes and mounting hardware in a kit. Tandem Master Cylinder represents the latest in refinements in brake pressure actuation and fluid control. The slotted flange mounting makes it a simple bolt on for many OE mounts including the popular Chrysler, Corvette, GM, and Ford Mustang bolt patterns and is compatible with manual or power brake system applications. Master cylinders are available in four bores sizes, 7/8”, 15/16", 1.00” or 1-1/8”, and three finishes, standard, ball burnished or black E-coat. The combination proportioning valve substantially simplifies wiring and brake proportioning adjustments on vehicles with custom brake systems. The combination block maintains full isolation between front and rear fluid circuits and is specifically designed to accompany the Tandem Chamber Master Cylinder. The combo valve and bracket are black E-coated for a performance look and long lasting durability. Stainless steel fluid tubes are precision bent with preinstalled plated steel tube nuts for a simple bolt-on installation between the Combination Proportioning Valve and the Wilwood Tandem Master Cylinder. Stainless steel button head fasteners thread into the bracket for a simple installation and years of durable, rust-free performance. Simply connect the fluid lines, bleed the system, and you're finished.
1.00 inch bore Wilwood part # 261-13269-BK HV TANDEM M/C KIT W/ BRACKET & PROP VALVE-1IN BORE , BLACK . $347.18 and free shipping Wilwood part # 261-13269-P HV TANDEM M/C KIT W/ BRACKET & PROP VALVE-1IN BORE,BALL BURNISHED . $347.18 and free shipping 1 1/8 inch bore Wilwood part # 261-13270-BK HV TANDEM M/C KIT W/ BRACKET & PROP VALVE-1 1/8IN BORE , BLACK . $347.18 and free shipping Wilwood part # 261-13270-P HV TANDEM M/C KIT W/ BRACKET & PROP VALVE-1 1/8IN BORE , BALL BURNISHED . $347.18 and free ahipping FREE SHIPPING COVERS LOWER 48 States only. If you don't see the part # you are in need of please e-mail , message or call us and we will get you the best price around. BE SURE TO CHECK WITH US FOR ALL OF YOU WILWOOD NEEDS. We will do our best to meet or beat any ones price . TNT-MOTORSPORTS , TULSA OKLAHOMA , 918-845-1935 Last edited by ksbrktracer; 10-08-2017 at 11:58 PM. |
TNT-MOTORSPORTS
Re: Wilwood master cylinder's and combination prop valve
Free shipping !!!!! And if you find a better price ... we will meet or beat it.
