Old 11-03-2017, 11:09 AM   #1
8man
AD cab weight
As the title says, does anyone know what the cab weighs? I'm building a dolly and was thinking about how much weight it should handle.
Thanks.
8man is offline   Reply With Quote
Old 11-03-2017, 12:45 PM   #2
MARTINSR
MARTINSR's Avatar
Re: AD cab weight
I don't have the number for you, but it isn't much. Here is a cart I made with a chunk of an old frame and wheels from Harbor Freight. I use the trailer dolly from Harbor Freight to roll it around. I ended up welding the jack stands to the cart. DAMN I am glad I did this. I would have never done it if I hadn't seen so many guys on this forum with carts, it makes things sooo much easier.
I was lucky to have a junk frame available to cut up. That gave me JUST what I needed, it's bolted down on the factory mounts keeping it all straight as I cut and weld it up. It will now bolt right on the stock frame without an issue.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-03-2017, 03:28 PM   #3
AZbent
Re: AD cab weight
Sorry no pictures. I made my dolly out of a couple of 2x6 and some inflatible casters from HF. If I keep the tires aired up, then I can move it around by myself with no problems. I drag it out of the garage every now and then just to do a good cleaning.
AZbent is offline   Reply With Quote
Old 11-03-2017, 03:47 PM   #4
mr48chev
mr48chev's Avatar
Re: AD cab weight
I'm going to say well under 400 lbs for the bare cab. I've manhandle them into the back of my pickup or a pickup box trailer by myself before. Can't do that anymore but did it quite often when I was in my 30's and 40's.
I've got a slightly longer section of frame as a dolly with wagon wheels on one end and casters on the other. That trailer dolly trick is a great idea. My frame section came from a hacked up burb frame that someone had taken front suspension parts off with a torch.
My ongoing truck projects:
Old 11-03-2017, 09:59 PM   #5
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Re: AD cab weight
Over on the stovebolt site, they have a DIY dolly made from an old wood pallet. Easy to come buy and usually free. Just throw some casters on it and your good to go.
GreasyLikeaBurger is offline   Reply With Quote
Old 11-04-2017, 03:25 AM   #6
Jesse Z
Re: AD cab weight
Brian
Serves not only as a dolly, but also a jig - brilliant!
Jesse Z is offline   Reply With Quote
Old 11-04-2017, 07:51 AM   #7
47 Fasttoys
47 Fasttoys's Avatar
Re: AD cab weight
I would guess 315# bare cab. Not a bad idea to build your dolly at final ride height. It helps if you want to set up engine or fender ride height.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 11-06-2017, 12:48 PM   #8
gigamanx
Re: AD cab weight
Brian
Hehe, that cart looks like its heavier than the cab MARTINSR
I used 2x4s and four 3" castor wheels from HF. Had no problems with the weight of the cab
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 11-06-2017, 12:58 PM   #9
8man
Re: AD cab weight
I decided to build a dolly I can use on other vehicles. I have a buddy who has a 64 Impala with the front clip on it, they lifted the body complete with interior off the chassis to do work. I saw it and decided to build a dolly that will handle just about anything.
I found this design on line and with the right size steel tube, I can expand it or contract it to fit whatever vehicle I want.
IMG_1794 by Robert Moorman, on Flickr
Then, I bought some more steel so I can flip it up on one side using some outriggers. When I get it built I'll post some pics.
Old 11-25-2017, 09:01 AM   #10
8man
Re: AD cab weight
Ok, it's kind of a gorilla for a body dolly, but it should let me roll the cab onto the back, front or either side by turning the cab on the dolly. Plus, it will expand to handle any car body I want to put on it, not sure it will "lay over on the back" for other cars, but it works for the 2 AD cabs I have.
First some fabrication.
IMG_1802 by Robert Moorman, on Flickr
A little more fabrication and the corners are ready
IMG_1807 by Robert Moorman, on Flickr
Here it is set up for the 48 cab.
IMG_1820 by Robert Moorman, on Flickr
Here it is under one of the cabs ready for set up.
IMG_1822 by Robert Moorman, on Flickr
Paint will have to wait because I want to get started on this cab.
IMG_1824 by Robert Moorman, on Flickr
Here it is with the cab on it.
IMG_1825 by Robert Moorman, on Flickr
It rolls great, but it does take 2 people or an engine hoist or gantry crane to roll it over, but it does work as hoped.
Since it expands/contracts in all directions, I can turn the cab on it so I can lay it over in any direction. Should make working on the sheet metal easier. That rust removal starts next.
Old 11-25-2017, 03:42 PM   #11
mr48chev
mr48chev's Avatar
Re: AD cab weight
Lots of ideas that all work. If I was doing a lot of welding on the cab and especially cab floor I'd want metal rather than wood though. Wood is great for storage and being able to move the cab around the shop but I'm always afraid of fires.
