07-29-2016, 09:52 PM | #126 |
Re: Another way to skin the cat; the High Torque 292 LS swap
Haha, I always second guess myself when I take a perfectly good running vehicle apart too! Looks killer though, the stance is right on!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-30-2016, 09:56 AM | #127 |
Ummm, Yeah, we definitely need a lot more info on that sweet little 68!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
08-03-2016, 09:32 AM | #128 |
And a few more of engine mods, like that sweet oil fill tube!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
09-02-2016, 11:09 PM | #129 |
I just stumbled across this build, awesome work on the LS!
The throttle body/air cleaner has given me ideas on my next future build. Keep up the great work!
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
09-05-2016, 08:45 PM | #130 |
I'm very impressed with the truck, great job.
I have a few questions though. How is the throttle set up? Throttle by wire or cable? I am wanting the same swap but with a manual trans in my '65, since I'm going with a manual trans I won't need any speed sensors Etcettera so I'm thinking of going with a standalone ECU. Is that something you would recommend? I think a standalone ECU would make it a lot easier to wire. |
09-07-2016, 12:09 AM | #131 | ||
09-07-2016, 05:33 PM | #132 |
Ok, thank you for the info.
09-12-2016, 09:26 AM | #133 |
That gold one is gonna be niiiiiice when you get it put together.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
09-13-2016, 04:05 PM | #134 |
Re: Gauges
I just stumbled across this build! Awesome build! I have a 69 Stepside Im trying to fix up when I have free time.
I was wondering how you did the lights on your gauges ? Looks like washer and some light socket .. Could you explain a little more on what you are doing ? Thanks!! Allen |
09-13-2016, 11:29 PM | #135 | |
Re: Gauges
You pretty much nailed what I did. The existing holes in the housing are made for the twist in sockets. You can get pigtails that fit, but they're about $3 each. Sockets like I used are $7 for 10 but they're just a bit to small to fit in the holes. So I used small machine screws to hold down some washers over the existing holes. |
09-13-2016, 11:31 PM | #136 |
09-14-2016, 07:27 AM | #137 | |
Re: Gauges
Thanks for the quick response and info. |
09-14-2016, 07:40 AM | #138 |
Dayj1, my hero, the smartest guy I know, I have a few questions. This pic looks shorter than your first set up. i want the sbc look. can you explain the reason why? I'm in the middle of this swap, on a 1980 gmc c15. i have a 4.8/4l60e, stock harness, and i have two options, the 4150 throttle body, or the thingy, figamabob, you created. my figamabob is an 1 inch thick, to compensate, for the tall fuel injectors. help me out and explain the madness. thanks in advance, Clark.
09-14-2016, 10:37 PM | #139 | |
Re: Gauges
There are some other possibilities out there. Search for "194 pigtail" and you'll see sockets with various mounting arrangements. Maybe there is something that will work better. |
09-14-2016, 10:54 PM | #140 | |
I'll probably end up using a taller element in the air cleaner (4" instead of 3") to provide enough room to squeeze a MAF in there like the setup on the '72. However, I do like the look of the shorter air cleaner and might just ditch the MAF and go with a speed density tune. Also, the adapter that goes from the 4150 flange on the intake to the 3 bolt factory 5.3 TB is 1/2" tall in my case. That allows the plug on the TB to just barely clear the fuel rail with factory truck injectors (standard injectors and not taller flex fuel injectors). This would be a non issue if had the foresight to make the adapter in such a way that the TB was turned 90 degrees and the electrical connector pointed toward the rear of the engine. Hindsight is always 20/20 The TB that you pictured is by far the easiest way to do this if you can absorb the cost. A cheaper way would be to buy one of the readily available adapters for a GM TBI throttle body to 4150 flange and use a TBI unit with the injector pod removed. It won't flow as much air as the Holley unit, but that shouldn't be an issue with a stock 4.8/5.3/6.0. I hope that helps to answer your questions. |
09-15-2016, 05:33 AM | #141 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
11-09-2017, 11:17 PM | #142 |
I'm curious about keeping everything with the stock tank need pics reloaded!
11-11-2017, 03:55 PM | #143 |
I'm too lazy to go back through this thread and fix all the links after the photobucket boondogle, but here are the tank related pics.
11-11-2017, 03:57 PM | #144 |
and more...
11-21-2017, 12:39 PM | #145 |
DayJ1, I'm in the process of a similar build. Trying to figure out how to run the pcv system. How did you run yours?
11-21-2017, 12:42 PM | #146 |
Easiest/fastest way is to use a breather in one of the valve covers and then use an LS6 valley cover for the PCV and run it back to the throttle body.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
11-21-2017, 04:19 PM | #147 | |
Sorry to hijack the thread but here's a picture of the smoke out the tailpipe. |
11-22-2017, 10:47 AM | #148 | |
The dirty side went from a vacuum fitting (the brass fitting in the intake just below and behind the carb mounting flange in photo 4) to a PCV valve in the driver's valve cover (photo 5). The PCV valve is the revised "fixed orifice" style for the early trucks and isn't really a valve. I have a vacuum tee fitting on it, because I ran the vacuum line over to the brake booster as well. |
11-22-2017, 10:50 AM | #149 |
That'll work for a speed density system. But, if you're running a MAF, the air entering the PCV system should be metered. Otherwise, you essentially have a vacuum leak.
11-22-2017, 11:36 AM | #150 |
True statement. I am running speed density on my '49.
