#251 |
Re: 71 C10 6.0 LS ground up build
Amen to that! Even if you're short, the other person driving may need the leg room. Those are super nice for the limited space you had to deal with.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579 |
#252 |
Thanks chucklee I'm happy with them shouldn't effect leg room either.
#253 |
Sound system looks excellent, subwoofer box really turned out nice with the vinyl wrap.
#254 |
Thanks I'm happy with how it turned out.
#255 |
Having issues with the Tmi door panels like mentioned in previous post. The lock knob holes in door panel won't line up perfectly and knob gets stuck. Door lock motors won't pull knob down or up. I enlarged the hole in both panels and ordered billet knobs in hopes that there thinner than the plastic knobs.
#256 |
I sent you a PM. The billet door lock pulls are generally larger in diameter than the plastic OEM ones. At least that was the case for the Ring Brother ones I ordered. The Ring Brothers door lock pulls would not even go in the original hole in the metal door skin.
#257 |
Finally got my tmi seat and door panels installed. Had fitment issues with door panels and tmi stopped returning calls and emails. I used smaller biller lock knob and biller inside handels to get it all to work properly. Anyway hers a few pictures. Also got my radiator cover done. Painted it body color and pUT stainless mesh being it.
#258 |
looking good cant wait to see it on the road
#259 |
That is all looking amazing.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
#260 |
![]() Join Date: May 2007
Looks fantastic! I will be installing A TMI interior as well, what exactly were your issues?
#261 |
Main issue was where door panel fits around lock knob hole. Had to drill out hole in door so knob would align. Also grind hole in panel larger. Had to drill holes in panel around inside door handel and install trim screw to hold panel tight against door.
#262 |
Decided to take off the vacuum booster and master cylinder and install a hydroboost system from Cpp. I flipped the hydroboost over so all fittings and hoses are on bottom side .
#263 |
Looks clean.
Quick question, Im in the process of filling holes in my firewall, what are the two wires you have coming out above your main fuse block connection? I was going to fill all those smooth but Im kind of running in the dark with what holes I should fill and keep or re-purpose to another use. |
#264 |
I used those for the drive by wire throttle pedal wires and also cruise control.
#265 |
#266 |
No problem can't wait to see your build come to life.
#267 |
Been driving the truck here and there and working out small issues. Ended up putting some beltech sport shocks on it the kyb shocks were a little to bouncy. Put it up on the lift today and inspected everything. Got all the dust off underneath as well. Had alignment set this week also.
#268 |
Looking good glad its on the road finally
#269 |
Thats one nice looking undercarriage.
#270 |
Thanks guys appreciate the feedback
#271 |
Decided to install a quick performance Ford 9" rear axle with 3.70 gears and wilwood disc brakes to match the front ones.
#272 |
Oh man that looks sweet.
#273 |
Sweet looking truck, the interior looks great!!!!
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#274 |
Thanks jeh appreciate it.
#275 |
Truck looks great. Do you have any pictures of the throttle pedal install?
