10-30-2017, 09:09 PM | #1 |
Pictures of Rear bag Set keeping stock trailing arms please!!!!
Just looking for pictures of bag placement with step notch on stock trailing arm or a link to a thread. I feel like i've looked everywhere just cant seem to find any pictures with people using stock trailing arms, any pictures will help
10-30-2017, 09:33 PM | #2 |
But Found Her 25yrs Later!
Re: Pictures of Rear bag Set keeping stock trailing arms please!!!!
Copy this whole string without the quotes " " :
" Trailing arms bags site:67-72chevytrucks.com " Then paste it in your address bar. Then across the top menu you should see a choice for images.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-30-2017 at 09:54 PM. |
10-30-2017, 11:04 PM | #3 |
Just keep searching you will find something.
10-30-2017, 11:20 PM | #4 |
thanks guys found what I needed through the first reply, sucks that some thread pictures are blocked by photo bucket now though
10-31-2017, 07:38 AM | #5 |
I found that if you click on the blocked picture it takes you to the actual picture on photobucket.
10-31-2017, 08:07 AM | #6 |
Goto my build page, I got start to now. Click link. Here shot of bag set up from ride tech, used same set up from stock to PB arms. Top cup takes two bolt to single all thread and spins on and hole for line. Couple flat plates.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-31-2017, 06:55 PM | #7 |
Heres the first set up. Top/bottom stiffner plates welded and powdercoat. I used a flat plate on top as well as bottom, the cup was wider than factory plate.
10-31-2017, 09:25 PM | #8 |
Is there a optimum psi at our desired ride hight?
10-31-2017, 09:34 PM | #9 |
Lets get that rear frame c notched.
10-31-2017, 09:38 PM | #10 |
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
11-01-2017, 07:34 AM | #11 |
I run around 40psi rear 80 upfront but probly need a 1" spacer to get psi down in front. It already lays bumper. The rear is pipe notchef but dont get into it because shocks. Before contact the bed hits pumpkin. I say again no notch needed til a hole in bed. Layin frame will need step.
11-01-2017, 07:41 AM | #12 |
For ride hight
11-05-2017, 09:11 PM | #13 |
11-15-2017, 09:52 PM | #14 |
just a note, if you are going to run tall tires, and want to run the truck lower than stock you will need to move the the trailing arms back about 1.5" and change the angle on the rear axle. adding some 4" channel between the trailing arm front bracket and the crossmember (moves the rear axle back 1.5".) when you reinstall the front brackets rotate them 180 degrees. (changes the angularity of the driveline)
11-16-2017, 12:47 PM | #15 |
I run 45psi in my rear bags. I don’t have a compressor or tank either. No notch either.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
