Old 11-27-2017, 07:26 PM   #1
72bigred
1960 Door latch...aftermarket or?
My door latch on the drivers side has never worked correctly. It locks but will not open the door from the inside. Just wondering if anyone has had exp with the aftermarket ones? Just hate to buy a used one and have the same issue..
1960 Short fleet... Thanks
72bigred is offline   Reply With Quote
Old 11-27-2017, 07:52 PM   #2
rvrfoot
Re: 1960 Door latch...aftermarket or?
Yep i got some after market ones. No problem.Name:  DSCN0904.jpg
rvrfoot is offline   Reply With Quote
Old 11-27-2017, 08:24 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Did you pull the interior panel off to see if you can see the issue?
DPowers is offline   Reply With Quote
Old 11-27-2017, 09:04 PM   #4
nsb29
nsb29's Avatar
Originally Posted by rvrfoot View Post
Yep i got some after market ones. No problem.Attachment 1711858
Attachment 1711857
Attachment 1711856
i like your work bench
nsb29 is offline   Reply With Quote
Old 11-27-2017, 09:06 PM   #5
rvrfoot
Thats funny some other guy said it looks like a 60's gauge cluster.
Old 11-27-2017, 09:07 PM   #6
rvrfoot
Oh and the wife was not happy when she seen it.
Old 11-27-2017, 09:38 PM   #7
72bigred
Pulled it apart.. It appears just a bend was the problem, I bent it back and it works correctly although obviously the metal is fatigued so it will probably happen again. Possibly need to replace but hate to replace things with Chinesium.
Old 11-27-2017, 09:52 PM   #8
rvrfoot
I will see what kind of shape my old ones are this weekend.
Old 11-27-2017, 11:06 PM   #9
vin63
It's Better With Nitro
vin63's Avatar
Just some assembly idiosyncrasies and interchangeability with the aftermarket parts from my experience. My truck also had worn out door controls. I also went with aftermarket controls, but I had to also get new latches, and new inner door handles as my OE handle no longer fit the splines. It would've been better if I had purchased the new door controls, latches, and inner handles at one time to save on the shipping from placing three separate orders.
The aftermarket parts probably will not withstand the same amount of abuse over time, but seem to work well enough.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-28-2017, 09:23 AM   #10
nsb29
nsb29's Avatar
Been there
Old 11-28-2017, 07:36 PM   #11
DPowers
DPowers's Avatar
Well at least you used a towel and they are clean.
Old 11-28-2017, 08:17 PM   #12
63burban
Chevy addict
It's usually an adjustment or tweaked linkage problem
63burban is offline   Reply With Quote
Old 11-28-2017, 11:38 PM   #13
Submariner616
Active Member
Attachment 1711857
Attachment 1711856
May I ask where you got these? Who is manufacturer? American made?
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 11-29-2017, 01:23 PM   #14
rvrfoot
Car and truck shop Orange California I'll check this weekend for the manufacturer
Old 11-30-2017, 12:42 AM   #15
Joe Pass
Joe Pass's Avatar
If I remember right...you have the door handle relay's switched rt/lt sides. The rod should be diagonal thru the access opening opposite of what you would think...I'm searching my build pictures but I did the same thing...You should be pushing on the latch instead of pulling
Joe Pass is offline   Reply With Quote
Old 11-30-2017, 01:03 AM   #16
Joe Pass
Joe Pass's Avatar
Wrong year but see the angle of the relay rod is on top Name:  1956-chevrolet-truck-stock-door-latch.jpg
