Brother's remote hood latch?
I'm wondering if any of you guys have tried the Brother's remote hood latch and if it works.
http://www.brotherstrucks.com/71-72-...tinfo/HLAC072/ My big concern is that when I pull my stock hood latch I still have to lift up on the hood. So how would that work if the remote is in the cab? |
Re: Brother's remote hood latch?
I would assume these work like modern hood latches: pull the cable inside the cab (unlocking the latch) and then push the handle under the hood, opening the hood.
I wouldn't mind having one myself! So, has anyone tried this? |
And why is it only good for 71 an 72? (according to the posted listing link)
Is the hood release that different on 69 and 70 models from 71/72? I could understand that the 67-68 hood release might be different or not fit with the hand brake mount.
On sale until the 31st.....tempting.
#5 | |
I guess the hand release lever comes out to a different location to fit each specific grill.
I did the version at the bottom half of the link below. I bought the cables for about $5 each at the junkyard.
Works like a charm. http://67-72chevytrucks.com/vboard/s...d.php?t=458433
1968 Chevrolet Fleetside C-10 1971 Chevrolet Fleetside C-10 |
Bummer,,, I was hoping someone had used this product before and I could get a review. I don't think I want to be the test subject on this one.
Somebody has to be the first to buy it in order to be the first to review it. I am thinking about it.
Well I placed an order on halloween for the 69-70 model and it's backordered (indefinitely?).
Will advise if it ever shows up.
![]() Join Date: Dec 2014
I ordered and received a latch for a 1972 Chevy from Brothers. Hoping to have it installed in the next couple of weeks and will post pictures. with a review.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Just received an email that my order (from 10/31) has "shipped" today 12/5/17. However there is no update to their website's order status page nor a tracking number.
![]() Join Date: Aug 2016
I bought one, just have not installed it yet. Yeah, I know...Useless. Sorry.
#15 |
Old member
Here are some do it your self posts.
If like me you like a good challenge. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=458433
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#16 |
I bought one from Brothers as well. Came with an instruction sheet with LMC truck on the top of it. I am assuming LMC is the one actually making these or having them made as they were on the LMC website first.
#17 |
LMC? Yikes!
#18 |
Yes LMC. I've got one installed, but not had the time to install the cable. Since I don't have the grill on my 70 GMC yet, I can use my fingers to release the lock. Looks like a good product.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
#19 |
I bought one off LMC because I was running billet inserts on the grille for my 68. I thought it was garbage, the pull latch was weak and broke on me. I ended up having to use vice grips for a while to pull on the cable. It worked but again the pull latch was weak, I got tired of dealing with it and didn’t want to mock something up on my own and ended up taking the billet inserts out so I could pop the hood the regular way. Just my experience with it
#20 | |
#21 | |
![]() Join Date: Jul 2015
#22 |
I just installed the LMC unit and it took some fiddling with the hood pin that goes into the latch to get it to release properly. I am concerned that the cable seems a little thin and not robust enough but hopefully it lasts a while.
The latch portion is fine though. This also forced me to adjust the hood so it pops up when the latch is released and it works great now! |
#23 |
As others have posted. I installed it and it felt like it was going to break. It took one person to push down on the hood, with another in the cab pulling the release without breaking anything. Off it came and I'll put the original back on. I don't need to cruise with a buddy just to open the hood. Pure garbage.
#24 |
Scrapper 1
some one will buy it put a better steel mesh cable on it and it will work fine.Its like any thing We as the guys that use it seen to be the ones that fix it and update it.Then LMC or other sellers will follow and steel the fix.
